Author Topic: Needing a 750a vacuum solenoid and check valve  (Read 2639 times)
Offline saavejo
« on: January 22, 2014, 05:37:47 PM »
Hondamatic owners,
I am looking for a vacuum solenoid and check valve for my hondamatic 750.  These items are mounted on the carb next to #2 carb.  Thank you - I appreciate it!  Jose ;)
Offline saavejo
Re: Needing a 750a vacuum solenoid and check valve
« Reply #1 on: January 23, 2014, 12:17:55 PM »
Honda owner's .  FYI I found this cool slavage yard in SC about a year ago, the owner's name is Roger, and he is very helpful and he is going to check on the solenoid for me. Please take a look at his salvage yard if you are in needs of parts at a very reasonable price.  Thank you and enjoy the tour! ;)
http://www.motorcycle-recycle-center.com/
Offline xntrik
« Reply #2 on: February 13, 2014, 01:26:04 AM »
I was just digging through a "Standard Engine Management" brand parts book at the shop, looking at neutral safety switches for a replacement park brake switch, and I remember seeing vac solenoids in there.  Pretty small ones by the look of them. May want to run to an auto parts store that still has the old fashioned BOOKS, not just computers for parts look-up, and see what you can find. I'll try to remember to look through there the next time I'm at the shop as well.
As for the check valve, that should be pretty easy to come across. I've seen lots of those on older Toyota cars. Also check "Dorman"
"HELP" application books for those, I've seen them there before.
May save a couple dimes making something work that's off-the-shelf. God knows what a yard might charge, and parts are getting scarce.
Offline xntrik
« Reply #3 on: February 13, 2014, 01:29:12 AM »
Just as a side note to anyone looking for a replacement vac diaphram/actuator (the part that actually moves the throttle linkage), I remember YEARS ago reading somewhere that guys had used an easily obtained actuator from an older Chrysler or Dodge car - a "K" car if memory serves.
Offline saavejo
« Reply #4 on: February 14, 2014, 05:10:47 PM »
Thank you for all the great suggestions!!!! ;) ;) ;) ;)
Offline Bill/BentON Racing
    • BentON Racing
« Reply #5 on: February 17, 2014, 02:40:04 PM »
May have those, let me know if still needed, Bill
BentON Racing Website
BentON Racing Facebook
Offline saavejo
« Reply #6 on: February 20, 2014, 07:24:32 PM »
Hi Bill,
Thanks for the reply.  Yes, I still need the solenoid and check valve for my 1978 Hondamatic.
You can email me at jose.saavedra@ngc.com or text me or call me at 321-951-5190.
Thank you and best regards,
Jose
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #7 on: February 20, 2014, 07:29:21 PM »
i have a complete set of 78a carbs that i wont be using.  hit me up if Billy cant help you.
Offline saavejo
« Reply #8 on: February 21, 2014, 05:05:38 PM »
Hi Bill,
A better number to call me or text me is my mobile 321-266-2195.  Also you can email me at jose.saavedra@ngc.com.
Thank you,
Jose
Offline saavejo
« Reply #9 on: February 21, 2014, 05:08:13 PM »
Hi Mr. Bastos,
Thanks for offering to help me.  If I do not hear from Bill I will definetely contact you.
Thanks so much!
Jose
