Author Topic: CB 550 tank inside - what is this and can it be saved?  (Read 2457 times)
Offline Chaser60
  • 75 CB550
« on: January 22, 2014, 06:19:11 PM »
Here are a few pics of inside of 1975 cb550 tank.   Gas that came out is a little bit of a dark brown / redish color.   Cap is corroded.  Is this a coating of some kind and if so, what should I do with this before the tank goes out for paint?
Offline sebastienb
Re: CB 550 tank inside - what is this and can it be saved?
« Reply #1 on: January 22, 2014, 07:36:28 PM »
Is it red ? Looks a little like redkote which is a liner
Sent from my Nexus 5 using Tapatalk
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: January 23, 2014, 08:12:38 AM »
I just went through this last summer. Even worse than your tank I had pin holes.
To remove the old liner, remove the fuel tap, put a couple of gallons of pure acetone in the tank and seal all holes completely. remember that using tape is no good as the acetone will dissolve it. I used a plastic wine cork shaved down to fit the fuel tap hole. Since your cap gasket looks old just use it to seal the filler cap as you will end up replacing it any way. I used a $8 morter mixing tray from home depot to set the tank in to keep from spilling on the ground. In the course of 24 hours or so turn the tank in varying angles so the acetone gets all over the inside and dissolves the crud completely. You might have to do this twice. Once your done do a mineral spirit rinse. You should be good to either reseal it or just derust it with phosphoric acid and use it as is. Remember that acetone will dissolve and ruin the paint if you want to keep the original so try and keep any spillage to a minimum and dispose of it properly.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Chaser60
  • 75 CB550
« Reply #3 on: January 23, 2014, 04:58:59 PM »
As always,  thanks for your input.   I was able to peel a little of this off and I believe it is red kote.   Tank now has MEK in it as that is the preferred solvent for redkote.   I pulled the cap off (drilled the pin on one side) and used a 1 7/8 inch freeze plug.  (the kind you tighten with a wrench to expand).   removed the petcock and used a rubber plug there with duct tape to hold it in place.    Will see what it looks like sometime tomorrow or next day.   Will deal with rust and recoating after I see the progress on the coating removal.   Tank is to be painted once i have this all happy on the inside !
Offline Chaser60
  • 75 CB550
Re: CB 550 tank inside - what is this and can it be saved - maybe yes !!
« Reply #4 on: January 29, 2014, 05:50:14 PM »
Well - again thanks to this forum, not only to those that replied to this thread but to the others that posted their processes to deal with tank coating and rust issues.   Here is where I am now - about 1 week later.
1 gallon of MEK used up.    As said above, plugged with freeze plug and rubber cork.   about 1/3 gallon MEK in.  let it sit, swish it around, leave tank in different orientations.   I did get some leak when left upside down from center of freeze plug, so dont recommend leaving it like that.   Just due to my schedule, it sat for 2 days in different orientations.   Poured it out, nasty red and stringy "skins"   Definitely red kite.    repeated this 2 more times over course of 5 or 6 days.
Didnt get a picture but most of the red kote was gone and by last 1/3 of MEK, the solvent was not coming out deep brown/red.
Next - Rinsed it with hot water over and over.  lots of the "skins" coming out and repeated until this stopped
Next - one bottle of the WORKS full strength.   let sit in different orientations and also swish the tank around and turn over and over....This sat for about 1 to 2 hours.   Poured it out and WOW it was really looking better.
Repeated with fresh bottle of WORKS and left it this time for about an hour.
Rinsed fully with warm water and baking soda.   Probably did about 4 to 6  gallons through the tank and used a heaping 1/2 cup of baking soda per gallon
One last rinse with warm water
drained all water then 1 quart of acetone which absorbs water very well.    drained it out and let it air dry
At this time, I am not going to re-coat with red kote, or mist it with MMO or other oil.    If it flash rusts, I will rinse one more time with works and then red kote it.
Before pics are up this thread.   Here is a couple after shots.
I think it looks pretty good, but am no expert.   Any thoughts or feed back on next steps are always welcome.
« Reply #5 on: January 29, 2014, 05:55:21 PM »
looks great...I would swish it with MMM, wd40, or 2 stroke oil and call it good.  Probably not much humidity in the air in VA this time of year, but once it gets humid, it will rust if you don't have some oil coating or some gas in it.
« Last Edit: January 29, 2014, 05:58:04 PM by seanbarney41 »
Offline LesterPiglet
  • 1977 CB550F2
« Reply #6 on: January 29, 2014, 05:57:26 PM »
It looks 100 times better than the tank on my bike at the moment.
« Reply #7 on: January 29, 2014, 06:36:28 PM »
Don't red cote it.  Looks like it came out pretty clean.
Offline reddyvv
« Reply #8 on: January 29, 2014, 07:17:01 PM »
Amazing difference!!
Offline 6adan
« Reply #9 on: January 29, 2014, 07:29:10 PM »
Looks like whoever did the red kote did not clean it first. I have used red kote in several tanks and have had no trouble with it.
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #10 on: January 29, 2014, 07:29:13 PM »
Wow looks awesome! No need to coat it at all.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
AJK
« Reply #11 on: January 29, 2014, 07:42:38 PM »
The before and after on your tank is excellent. I've got some spares to try that out on.
Also, if your considering lining the tank, POR15 is excellent stuff too. I've attached an example pic of my tank with POR15. My painter done this and prepped it up correctly. Its what he always uses. Its good stuff.
Offline Chaser60
  • 75 CB550
« Reply #12 on: January 29, 2014, 07:48:58 PM »
Thanks all.    I hear great things about red kote from many sources, so agree it was likely mis-applied or very very old.  Likely both.   No way for me to know.     will see how it looks in the morning and if its flashed, will clean it and use the alcohol and then fog it with MMO.   I would love not to coat this at all, but sure as hell dont want to repeat this week of nasty chem's especially after I have the outside painted.
cal -  you're killin' me, but no worries,   Andy should definitely take good care of repeat customers(you)  that also give him referrals (me).   I cant wait to start putting this thing back together.
Cheers all
