Author Topic: New guy, new project - tank modification  (Read 1901 times)
Offline Hutch
  • 1982 CB650SC
« on: January 23, 2014, 07:15:52 AM »
I'm planning on what I'll call an "elegant" modification to my 1982 CB650SC.  I'd like to eliminate the tab on the lower portion of the tank so that the tank has a relatively straight line across the bottom.  This will be paired with some custom side guards and a rear cowel I'll fab up.  I wanted to throw this out to the forum for ideas on how best to modify the tank.  My initial thought was to leave enough sheet metal so that I can fold over the flaps rather than make a small patch.  Does anyone have any thoughts/ideas/experience cutting a tank?
Offline Hutch
  • 1982 CB650SC
Re: New guy, new project - tank modification
« Reply #1 on: January 23, 2014, 09:00:56 AM »
I don't plan on removing the entire pinch weld only that portion of the tank marked in yellow on the original picture.  This crud diagram might help explain.  Basically I would make a small vertical cut (red line) after cutting of the portion of the tank I want removed.  Rather than adding a piece to fill the gap, I would fold over B then A after some trimming.  There would be overlap, so the next step would be to cut through both A and B after they're folded over to create a butt joint/seam.  I expect the resulting joint to be 4-6 inches plus any collateral damage to the factory pinch weld.  I'm OK with the tab from the factory pinch weld visible on the rest of the tank, although I may end up gently folding it over.
Love to hear from some guys who cut into tanks.  I'm trying to keep the effect on the factory weld to a minimum.  My hope is that the small new welded seem is not visible on the underside of the tank, although I'll hope to clean it up enough so that its not evident anyway.  I'm OK with the cutting and shaping, but plan to find someone far more skilled with a tig welder to make sure the tank seals properly.
« Last Edit: January 23, 2014, 09:11:52 AM by Hutch »
