Author Topic: Alright, I figured out why it seized.  (Read 3323 times)
Offline Carver
« on: January 23, 2014, 02:58:53 pm »
 :o So how bad do you think my bottom end is mangled? and also I couldn't pop the piston out today but why would it be doing this? rod small end stretched out?
VIDEO0005
Cb 750 k3
Cb 450 dohc k4
Offline LesterPiglet
  • 1977 CB550F2
Re: Alright, I figured out why it seized.
« Reply #1 on: January 23, 2014, 03:02:41 pm »
Am I seeing that right? Apart from the obvious piston damage, the bore looks much bigger than the piston and out of round.
Offline Bailgang
  • Scott
  • Indiana
« Reply #2 on: January 23, 2014, 04:28:48 pm »
The vid is with the jugs already removed, that bore you're seeing is the block itself where the sleeves sticking out on the bottom of the jugs go in and align.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: January 23, 2014, 04:33:00 pm »
Looks bad.  Why did you start another thread rather than continue the other?...Larry
Offline Carver
« Reply #4 on: January 23, 2014, 04:51:40 pm »
yep yep, a piece of the sleeve fell in to my cases  ;D It was popping out of second gear anyways so i guess i'll fix that and bump this up to 836. I'm just trying to figure out HOW the sleeve broke? Maybe the piston went first and since it had so much "mobility" it smacked the sleeve and seized it while i was riding?
Cb 750 k3
Cb 450 dohc k4
  • 1977 CB550F2
« Reply #5 on: January 24, 2014, 12:27:10 am »
I must go to bed earlier.   ::)
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #6 on: January 24, 2014, 01:17:58 am »
Maybe it was mishandled by a PO in a previous install. Cracked the sleeve and didn't notice. Over time vibration has done it's worst. The piston should lift up if the crank turns. Maybe a clue as to where the missing piece is?
Build threads:
1977 CB750 F2
1958 Norton Model 99
« Reply #7 on: January 24, 2014, 02:07:05 am »
If the crank ain't turning when you pull that piston you got a totaled crank and rod mate
Offline Carver
« Reply #8 on: January 24, 2014, 02:20:02 am »
I wanna be mad that the majority of my engine is wrecked and i'm unemployed and can't fix it but all i can do is sit back an laugh at how comically the whole engine failed.
Cb 750 k3
Cb 450 dohc k4
Offline Carver
« Reply #9 on: January 24, 2014, 02:21:00 am »
yep, the piston just moves up and down on the rod, no crank movement at all.
If I had to guess why the crank isn't moving it would be because a piece of my bore is lodged down there.
« Last Edit: January 24, 2014, 02:26:49 am by Carver »
Cb 750 k3
Cb 450 dohc k4
Offline calj737
  • I refuse...
« Reply #10 on: January 24, 2014, 05:42:18 am »
Carver - good on you for having a laugh at your engines condition. It could have been far worse, seizing up whilst riding at high speed and them throwing your arse over tea kettle into traffic. Then, the meaning of being "lodged" would take on a whole new perspective.
Delighted you are well, condolences for your motor!
Offline iron_worker
« Reply #11 on: January 24, 2014, 10:12:27 am »
I would bet that the rod bearing seized/spun which by now obviously the rod bearing, rod journal, and crank journal are now all obviously completely munched. Once that happened it allowed the rod to slap around enough to smack the bottom of the sleeve.
You've got a lot of scrap parts on your hand.  :o :-[
IW
Offline MikeKato
  • Milwaukee WI
    • TCB true life stories
« Reply #12 on: January 24, 2014, 10:44:38 am »
It's advertised as a 87 but it's a 78. about a half hr from you. asking $75 but says he's flexible.
http://tampa.craigslist.org/hil/mpo/4299410797.html
Offline martin99
  • UK Based, Non-
« Reply #13 on: January 24, 2014, 11:34:41 am »
Good that you're being so positive about it mate, not sure I would. But as has been pointed out, it's the engine that's mangled, not you!
Are you going to take it apart? It'd be interesting to see exactly what happened.
Build threads:
1977 CB750 F2
Offline rb550four
« Reply #14 on: January 24, 2014, 12:20:42 pm »
I would buy the other $75 motor on CL and do some detective work later. heck, it'll cost you that for rings anyway and you wouldn't be without a runner
« Last Edit: January 24, 2014, 12:22:33 pm by rb550four »
Offline Carver
« Reply #15 on: January 24, 2014, 01:40:21 pm »
I'm gunna give him a call, how much of the engine internals are interchangeable? Looks like im gunna need the crank, pistons, jugs, actually can I just drop this engine in my frame while I build the other one up? I don't see why not Just wanna confirm its possible and none of the mounting points changed over the years.
Cb 750 k3
Cb 450 dohc k4
Offline Carver
« Reply #16 on: January 24, 2014, 05:17:56 pm »
Yeah, the plan right now i guess is to pop the CL engine in if I can get it and then rip this one apart and see how messed up it is and when I get a job build it in to a mild engine for touring which is why I bought the 750 in the first place.
Cb 750 k3
Cb 450 dohc k4
« Reply #17 on: January 24, 2014, 05:54:51 pm »
We always used them for mild touring, they just need a good tuneup and a clean set of carbs. That's the beauty of these bikes, they still can be inexpensive. Keep the old motor for projects and parts.
« Reply #18 on: January 24, 2014, 06:06:17 pm »
The CL engine looks like a 78 F engine by looking at it and the other parts. They have a few quirks of their own like valve stems etc, especially if not well cared for. Be careful you don't end up with another junker  ;)
Offline MikeKato
  • Milwaukee WI
« Reply #19 on: January 24, 2014, 06:25:24 pm »
The guy said the parts were "off a running bike" and I know a person should take that info with a 50lb block of salt but for $75 or less, I would take the chance. Maybe ask the guy if HE heard it run while negotiating and if so,did it smoke. But,again,for $75 or less it's a good bet. Maybe he can get the whole pile of parts(except the hacked up frame) for $125 and come out with the motor free after selling off parts.
Offline mrbreeze
  • Not your average
« Reply #20 on: January 24, 2014, 07:10:24 pm »
If the CL engine a 78F....won't there be a problem with the chain lining up to a K3? I've never owned a 77-78 so I don't know.
MEMBER # 257
Offline MikeKato
  • Milwaukee WI
« Reply #21 on: January 24, 2014, 07:18:37 pm »
I was thinking about that too. I know there's 2 different size spacers for the brake side. A member named Radam threw an early (1974?) motor in a 78f a couple years ago but I don't know if he had to change the spacer size.
Offline Carver
« Reply #22 on: January 24, 2014, 07:29:19 pm »
since we're talking about it does anyone see anything in that pile of parts worth flipping so I can start sourcing parts when I bust the case open? I see gauges, and the exhaust maybe but not sure what to look for on the F series?
Cb 750 k3
Cb 450 dohc k4
Offline mrbreeze
  • Not your average
« Reply #23 on: January 24, 2014, 07:36:59 pm »
I thought he wanted $75 for just the engine. If you get all of that other stuff you can flip a lot of it.
MEMBER # 257
« Reply #24 on: January 24, 2014, 09:48:22 pm »
Read up as there may be some other parts like a sprocket carrier or such that you would need to line up your chain with a 73 frame and 78F engine. Never done it here but plenty of threads. Also pistons etc would not be the best situation for you for parts swap into your K3 motor.
