Author Topic: 1976 550f  (Read 431 times)
Offline anji mehra
1976 550f
« on: January 23, 2014, 11:15:29 PM »
Hi
Need expert advice on how to free the master cylinder piston / plunger which seems to have welded itself to the cylinder , please.
Have managed to remove the cir clip which itself was a nightmare. Tried boiling the assembly for an hour in water, but no luck. Don't want to try stron arm tactics in case I damage the alloy casting. Any advice will be greatly appreciated. Saw Sullys garage video on this too
Thanks
Anji
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
Re: 1976 550f
« Reply #1 on: January 23, 2014, 11:31:40 PM »
If it's really stuck in there some have had luck by fabricating a drilled bolt with a grease nipple & pumping it out with a grease gun.
If you want my 2 c worth, I'd toss it in the bin & buy one of these.
http://www.davidsilverspares.com/CB550F-SUPER-SPORT-1976-USA/part_123897/
I understand that they take the original kit if in future years you need to rebuild it, you can.
I have one of these on mine & can vouch that it works a treat.
Cheers.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline anji mehra
Re: 1976 550f
« Reply #2 on: January 24, 2014, 03:53:38 AM »
Thanx Frostyboy. Will pursue this alternative
Anji
