Author Topic: Gouge in cylinder head  (Read 1160 times)
Offline Anton
« on: January 25, 2014, 07:33:53 PM »
was cleaning up the head today around the valves and uncovered this....
Offline Anton
Re: Gouge in cylinder head
« Reply #1 on: January 25, 2014, 07:35:31 PM »
I have no idea how serious this is, any thoughts??
Offline 750cafe
« Reply #2 on: January 25, 2014, 07:43:27 PM »
I have no idea how someone did that with a straight chisel or why.   ???
But, although it is not good, it is not terrible.
You can try to tap the points back outward with a flat round chisel and could fill the void with some metal epoxy and mill or sand flat.
If I did not have another head, I would probably just try to peen it back with a ball-peen hammer carefully and file it flat.
Are you planning to re-do the head anyway?
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
Offline Anton
« Reply #3 on: January 25, 2014, 07:47:21 PM »
what do you mean re-do?
Offline Trad
« Reply #4 on: January 25, 2014, 07:57:04 PM »
Don't sand it out! Just take some 400 and wetsand any of the high spots off. It will be fine.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline 750cafe
« Reply #5 on: January 25, 2014, 08:00:47 PM »
Clean the combustion chambers, lap the valves, replace the valve seals...
Eric
Offline Anton
« Reply #6 on: January 25, 2014, 08:22:13 PM »
yes i was planning on re doing them
Offline tomkimberly
« Reply #7 on: January 25, 2014, 09:32:50 PM »
It's only cosmetic, pretty much a non-issuse.
Tom
« Reply #8 on: January 25, 2014, 09:39:21 PM »
Tap it down gently with a small ball pien....like a 2 or 7 oz, if you can find one...aka gasket hammer..
Offline Anton
« Reply #9 on: January 25, 2014, 09:41:11 PM »
ok, thanks guys. Very relieved ;D
