Author Topic: Crankshaft Puller/Installer  (Read 1304 times)
Offline krusty
« on: January 25, 2014, 09:36:42 PM »
I need to pull the crankshaft of my 78 DT250 but need special tool i.e. puller (& installer). I've already split the cases but the c/shaft won't budge from the LHS.
I see that Tusk sell them and they appear to be good quality. My question  are there any other brands available because Tusk seem to be the only one I could find.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Re: Crankshaft Puller/Installer
« Reply #1 on: January 25, 2014, 09:43:32 PM »
Use a press..
Offline simon#42
  • liverpool
« Reply #2 on: January 26, 2014, 04:30:05 PM »
be careful with that press the cases will easily distort , put the crankcase half with the crank in into the oven for 10 min and it will fall out of the case with the main bearing .
Offline krusty
« Reply #3 on: January 26, 2014, 06:54:02 PM »
I had read somewhere recently, advising against using a press, possibly for that reason. I came across a good vid showing these (Tusk) tools in use.
Motorcycle bottom end rebuild part 2 (of 3) crank & bearings
Would still like to know if there are other makers. Haven't been able to find any so far that look like they do the job.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
