Author Topic: barnfind 500 vin help  (Read 2654 times)
Offline tblem
« on: January 26, 2014, 05:10:31 PM »
I can't seem to locate a vin decoder on the site or google.....I would rather not have to buy a $25.00 + or - book by Honda to find out what year model bike I have. My frame number is 1015827. The actual vin plate reads cb500-1045827.  Any help would be appreciated.....Tim
Offline Powderman
Re: barnfind 500 vin help
« Reply #1 on: January 26, 2014, 05:13:38 PM »
1971 -Frame CB500-10000001~
The 72s were : CB500-20000001~
The 73s were : CB500-21000001~
Your VIN plate # is different than whats on the frame?
This info was easy to find by Google searching "Honda CB500 VIN"
« Last Edit: January 26, 2014, 05:17:09 PM by Powderman »
Offline tblem
« Reply #2 on: January 26, 2014, 06:07:32 PM »
It is probably the same number....I did not clean it as I should have ...I need to brush the barn funk off and verify........Thanks for the help!....I was told by the giver that it was a 71 more than likely..........Tim
Offline Johnie
« Reply #3 on: January 26, 2014, 06:11:43 PM »
Welcome to the forum. You can also take a look at the sticker on the steering head. It should have your frame number stamped in and you will also see a month/year in the corner. That will tell you the month and year it was made. Keep in mind the bike could be a 1971 and titled as a 1972. Once you get up to speed how about a few pics.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #4 on: January 26, 2014, 07:03:59 PM »
Here's the model guide for you...
http://www.sohc4.net/cb500-model-guide/
You may want to download the service manual found elsewhere on this site.
Offline calj737
  • I refuse...
« Reply #5 on: January 27, 2014, 03:34:51 AM »
Tblem- just for clarification, the frame and engine #s will differ. The right side of steering head should have a sticker with the production date and info, and the left side a stamped in VIN. The stamp and sticker should definitely match.
Offline Powderman
« Reply #6 on: January 27, 2014, 08:44:19 AM »
He wasn't saying the engine number was different. He said the frame number and the VIN number were off by 30,000. I think he misread the numbers. Vin numbers don't go by the engine number on Honda's as far as I know.
Offline calj737
  • I refuse...
« Reply #7 on: January 27, 2014, 12:30:09 PM »
Im aware of what he said, but since he indicated he may have misread the VIN, I wanted to express the locations and differences, in case this was his first visit/SOHC.
Offline tblem
« Reply #8 on: January 27, 2014, 05:43:15 PM »
I took the time today to clean the barn funk off of the id numbers and as suspected I had one number wrong. The frame and the vin are the same. Sorry guys for the bad info. I did find out it is a 1971.....Thanks for the help.............Tim
« Reply #9 on: January 27, 2014, 11:33:28 PM »
I would say that is 5th or 6th month 1971. Does it not have a vin plate on the RH side of the headstock If you have the details from the vin plate and also frame and engine i would appreciate the details to go into my ever increasing data list
« Last Edit: January 27, 2014, 11:36:10 PM by bryanj »
