Author Topic: Head Nuts - Standard or ?????  (Read 3709 times)
Re: Head Nuts - Standard or ?????
« Reply #25 on: February 17, 2014, 09:58:58 AM »
FASTENAL
$.51/ea
Fastenal Part No. (SKU): 11508216
http://www.fastenal.com/web/home
« Last Edit: February 17, 2014, 10:30:45 AM by flybox1 »
Offline 750cafe
« Reply #26 on: February 17, 2014, 10:26:18 AM »
These? http://www.fastenal.com/web/products/_/Navigation?term=8mm+flange+nuts&termca=&termpx=&sortby=&sortdir=&searchmode=productSearch&zipcode=&filterByStore=&filterByVendingMachine=&r=%20~|categoryl1:%22601071%20Cutting%20Tools%209and%20Metalworking%22|~%20~|categoryl2:%22601114%20Tooling%20Components%22|~%20~|categoryl3:%22603339%20Workholding%20Fasteners%22|~
Or these? http://www.fastenal.com/web/products/_/Navigation?term=8mm+flange+nuts&termca=&termpx=&sortby=&sortdir=&searchmode=productSearch&zipcode=&filterByStore=&filterByVendingMachine=&r=%20~|categoryl1:%22600000%20Fasteners%22|~%20~|categoryl2:%22600072%20Nuts%22|~%20~|categoryl3:%22608620%20Flange%20Nuts%22|~
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
« Reply #27 on: February 17, 2014, 10:29:54 AM »
sorry...the link i posted doesnt lead directly to the part.
look up by the sku 11508216
https://www.fastenal.com/web/home
« Last Edit: February 17, 2014, 10:36:04 AM by flybox1 »
Offline 750cafe
« Reply #28 on: February 17, 2014, 10:44:49 AM »
As usual, I called my local store and he said that they have no flange nuts in stock.
Same old, same old with them. EVERYTHING HAS to be ordered!
I checked the availability of those too. The nearest store to me is over a couple of hundred miles away. As usual. They seem to stock NOTHING!
$14.00 plus tax if I have them sent to a nearby store or $17.00 to have those 16 nuts sent to my door.
Eric
« Last Edit: February 17, 2014, 11:48:07 AM by 750cafe »
Offline KrautKoffin
« Reply #29 on: February 18, 2014, 05:12:13 PM »
Are these for the 750 or 550?
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
Offline bert96
  • past ride
« Reply #30 on: February 18, 2014, 06:01:12 PM »
I'm in for a set of 16, (750cafe )if they are the same as #11508216.
I'm looking for these nuts
Sent from my HTC_Amaze_4G using Tapatalk
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline bert96
  • past ride
« Reply #31 on: February 18, 2014, 06:03:42 PM »
Dynoman sell these nuts but it would cost me 32$ just for the shipping!!!?
Sorry but its too much for me...
Offline 750cafe
« Reply #32 on: February 18, 2014, 08:26:44 PM »
I will buy 100 or 200 of them if there is demand here. And send 20 with each order.
I already have a running order going for more SS Allan head bolts, etc to replenish my stock anyway and
they have a minimum order amount that I need to spend to get the GOOD prices.
I added up most of my receipts from last year and almost had a stroke!
Over $1,300.00 just for the SS bits! Some of my bikes do bling a bit now though.  ;D
BTW, I send bike parts to Canada and Australia/New Zealand all of the time. Those chaps get bent
by their local parts houses and I would want to find someone like ME to find parts from too.  ;)
The worst part about sending parts to those chaps is no insurance and no tracking numbers!
So far, in the past 5-6 years, all parts have arrived safely.
Eric
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #33 on: February 18, 2014, 08:39:22 PM »
what kind of price you talking Eric?
Offline timbo750
« Reply #34 on: February 18, 2014, 08:40:45 PM »
750cafe
Thanks for all the research. I would be interested to get stuff sent here to Aus. I have had a few things sent so far and the only problem was with an order from Lulu for the homdaman book that 32 working days, everthing else is 1 or 2 weeks.
Are you saying that you can also supply ss bolt sets for the covers? Would be good to gey as one and maybe save on postage.
Also there was one thing I got cheap and maybe cheaper here. It the bolt used to remove the generator rotor, $2.40 a bargain.
Cheers Tim
Project 1 CB750 - http//forums.sohc4.net/index.php?topic=126864
« Reply #35 on: February 18, 2014, 09:24:28 PM »
What grade are the nuts you found? Are they bright plated?
Offline 750cafe
« Reply #36 on: February 18, 2014, 10:09:09 PM »
750cafe
Cheers Tim
I will need the sizes (typically 6mm X1.00 pitch) by length and quantities of each needed. plus with or without SS flat washers or SS lock washers.
Some od lengths like 65mm are much more expensive than just getting 70mm and cutting to 65. I am doing just that to one of my projects tomorrow.
Eric
Offline 750cafe
« Reply #37 on: February 18, 2014, 10:12:16 PM »
Grade 10 and plated IIRC. I posted my findings a page ago and this site is not so easy for me to maneuver though.
They might be plain. I will call tomorrow. Any preference?
Eric
« Reply #38 on: February 19, 2014, 02:49:20 AM »
M8 x 1.25 nut is a standard nut possible to find almost everywhere.
Almost same size as HONDA std head nut but harder quality (10.9) able to withstand around +40% torque than 8.8 grade
http://www.ebay.com/itm/10-M8-1-25-Pitch-Hex-Head-Flange-Nuts-Phosphate-Metric-10-9-Grade-Bolt-/130593854198?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item1e680012f6
EDIT: I asked the seller about the size.
The hex head is 13mm. The total width with flange is 17mm. The height is 8mm.
For the higher strong not with same hard grade of 10.9. Search for DIN6331 which is the standard for that nut.
« Last Edit: February 19, 2014, 10:32:06 AM by PeWe »
« Reply #39 on: February 19, 2014, 06:27:15 AM »
I was asking about the grade,  to see if it was as least as strong as a stock one.
Heat treated nuts are often not plated. I am thinking the plating, may not help the torque readings.
Offline bert96
  • past ride
« Reply #40 on: February 27, 2014, 11:16:59 AM »
any updates?
Bert
Offline 750cafe
« Reply #41 on: February 27, 2014, 12:02:36 PM »
Eric
I double checked and this is correct. Not much interest in me ordering these so...
Eric
« Reply #42 on: February 27, 2014, 01:09:15 PM »
I'll update later when I have installed the higher nuts of grade 10.9.  Installation of ign switch saving relays have taken my time.
I'll abuse my CB750-k6 frame with a saw this weekend,  frame mod kit.
Then possible to open valve cover taking things off, replace nuts one by one without harming the head gasket.
I have to measure the cam before as reference of the procedure and tools used so it will come back in as I want.
Nic
« Reply #43 on: February 27, 2014, 04:35:41 PM »
I bought 14 of these from that seller, he added the extra 4 at no extra charge.
Offline KrautKoffin
« Reply #44 on: March 15, 2014, 02:13:19 PM »
Who do I have to #$%* around here for some upgraded 500 nuts?!
74 cb550
