A lot more struggling, and a little progress...Put some more work into the pd42's. The choke would not close. Thought the shaft might be bent, so I swapped the one from from some 41a's I had.
![](http://i1309.photobucket.com/albums/s630/seanbarney41/100_0609_zps12a7655b.jpg)
It didn't help much, but in the process discovered that the throttle slide was sticking above half throttle on carb #4. Turns out, carb body #4 was warped or bent. Replaced it with #4 from the 41a's.
![](http://i1309.photobucket.com/albums/s630/seanbarney41/100_0611_zps028c339e.jpg)
Here is my trick little tool for fishing the washer and o-rings out of mixture screw hole.
![](http://i1309.photobucket.com/albums/s630/seanbarney41/100_0610_zps050200db.jpg)
Got it all back together and the accelerator pump was no longer working. Fixed that with the actuator spring from the 41a's. I am not allowed to tell you how that #$%*ed up spring got in there and it wasn't me who put it there.
![](http://i1309.photobucket.com/albums/s630/seanbarney41/100_0621_zpse8f257be.jpg)
Here is the #$%*ed up spring...
![](http://i1309.photobucket.com/albums/s630/seanbarney41/100_0619_zps56125be7.jpg)
and what it is supposed to look like on the 41a's...
![](http://i1309.photobucket.com/albums/s630/seanbarney41/100_0620_zps48b9b33b.jpg)
