Author Topic: stock cb550 exhaust and brake pedal issue.  (Read 9154 times)
Offline Jimsun
« on: January 30, 2014, 03:52:15 PM »
Hey guys i'm stumped because i can't figure out why my brake pedal is hitting the 4th pipe after re-installation. Im 100% sure it wasn't hitting before i took it apart as i have riden it.
I've looked at the exploded diagram and I have used the right pipe for the right location (hard to get it confused as 3rd and 4th have a connecting tube) and have all the necessary parts.
I tried pushing the 4th pipe away from the brake pedal as i tighten the exhaust mount bolt. However, as i tighten the collar while my other hand still pushing the 4th pipe away, the pipe will adjust itself and move outwards causing it to sit right below the brake pedal when the outer nut is tightened.
74 cb550
Offline goldarrow
  • one day, i'll be an
Re: stock cb550 exhaust and brake pedal issue.
« Reply #1 on: January 30, 2014, 04:36:03 PM »
post some pics
CB550 K0
Offline SohRon
« Reply #2 on: January 30, 2014, 05:12:58 PM »
When you reinstalled the brake pedal, did you use the alignment marks on the pedal and lever shaft to align everything? This would cause the pedal to sit kind of wonky if you didn't.
Offline Jimsun
« Reply #3 on: January 30, 2014, 05:18:35 PM »
I did not disassemble the brake pedal at all.
post some pics
Here's the youtube video of it.
It's being uploaded as i type so maybe a minute or 2 for it to be seen by others..
http://youtu.be/Sp9Fqzw8fa0
« Last Edit: January 30, 2014, 05:37:32 PM by Jimsun »
74 cb550
Offline bender01
« Reply #4 on: January 30, 2014, 06:27:06 PM »
Do you have the exhaust brackets upside down or reversed?
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline goldarrow
« Reply #5 on: January 30, 2014, 06:29:29 PM »
You need to readjust your brake adjuster by the rear wheel hub
CB550 K0
Offline Vinhead1957
« Reply #6 on: January 30, 2014, 06:33:45 PM »
Doesn't that exhaust bracket belong on the inside of the frame with the other bracket?
Offline goldarrow
« Reply #7 on: January 30, 2014, 06:34:58 PM »
You can have it mounted either side of frame is fine
CB550 K0
Offline LesterPiglet
  • 1977 CB550F2
« Reply #8 on: January 30, 2014, 07:04:45 PM »
Then try it on the inside.
Offline Jimsun
« Reply #9 on: January 30, 2014, 10:02:01 PM »
I tried that but theres a significant gap (1inch))
Theres no way itd work like that. + the peg has to stay in the outside. If the mount is placed in the inside the the foot peg bracket would clamp onto the exhaust backet. I don't know if that makes sense but i can take a pic if needed.
They can only be one way because the exhaust clamp at the very end only aligns at this setup.
How does that affect the horizontal motion of the pedal? I have the rear properly set up iirc
74 cb550
Offline goldarrow
« Reply #10 on: January 30, 2014, 11:00:22 PM »
I'm guessing you had your rear wheel off before this issue?  Your brake shoes may be worn, or the arm that attaches to the spline on the hub is not set to correct position.  Try playing with position of that arm that attaches to the spline.
CB550 K0
Offline Jimsun
« Reply #11 on: January 31, 2014, 05:21:47 AM »
Brake shoes are still good. I took pictures and have followed the exploded diagram as a guide for installation. From my pictures it was installed right.
I just rechecked and seems to be done correctly.
I still dont understand how having the rear wheel off affects the position of the brake pedal if it's range of motion is strictly vertical.
Its as if the brake pedal needs to be offset more to the outter side but this will cause it to not bite on the teeth thingy.
« Last Edit: January 31, 2014, 05:24:52 AM by Jimsun »
74 cb550
  • 1977 CB550F2
« Reply #12 on: January 31, 2014, 06:52:51 AM »
In your video I see you have it at a point where it doesn't hit. Why not tighten the header at that spot?
Offline Jimsun
« Reply #13 on: January 31, 2014, 06:59:28 AM »
Yea i know what you mean but even if you tighten the header and while holding the position, it will gradually revert back to the point where it will hit as the outter screw is tightened. If i dont tighten the screw, the pipe will be lose. Which from my what i recall prior to disassembly, wasnt loose.
74 cb550
  • 1977 CB550F2
« Reply #14 on: January 31, 2014, 07:04:46 AM »
Has the rear mounting bracket moved a bit? I would try tightening it in the no-hit position and applying some pressure to the rear pipe at the mounting. It seems odd.  :-\
Offline jonda500
« Reply #15 on: January 31, 2014, 07:10:49 AM »
yes, try loosening all three exhaust bracket nuts/bolt first and then with them quite loose repeat what you've been trying again?
A starter clutch thread:
Offline Jimsun
« Reply #16 on: January 31, 2014, 07:31:11 AM »
What do you mean by no hit position?
yes ive tried something similar. But the main issue is that if its not tightened(loose) it wont hit but if i go over pot holes, it will revert back. Hence why i know that it should be tight.
There must be something im not doing right.
I appreciate the time guys.
74 cb550
  • 1977 CB550F2
« Reply #17 on: January 31, 2014, 08:43:02 AM »
No-hit. You have the header in a position where the brake does not foul. Tighten it up there. Then move to the rear bracket. Apply pressure when it's loose and tighten that.
Offline Jimsun
« Reply #18 on: January 31, 2014, 08:57:33 AM »
i see. I will try this tonight.
74 cb550
Offline jonda500
« Reply #19 on: January 31, 2014, 06:32:03 PM »
might be a good idea to first pull the offending pipe back off again and check there's nothing stopping it from seating squarely against the head like a deformed copper gasket or something?
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #20 on: January 31, 2014, 08:22:52 PM »
are you sure you have the correct brake pedal?
I like berries.
Offline Oddjob
« Reply #21 on: February 01, 2014, 05:04:06 AM »
Have the brackets been off the exhausts for some reason? trying to find out whether there's a possibility that the wrong bracket has been fitted, if they haven't been off then it's clearly a mispositioning issue.
Offline SohRon
« Reply #22 on: February 01, 2014, 08:14:13 AM »
From the pic, your pedal still seems to be sitting too low; the shaft should nearly touch the foot peg mounting nut just above it and the foot pad on the pedal should sit just below the footrest. Can we get a more face-on pic to see just where everything is oriented? compare your pic to the one I posted above. I'm wondering whether it's the wrong pedal, or maybe it's been damaged somehow... Also, brake pedal travel in the video is quite excessive - the pedal should move only a half inch or so...
« Last Edit: February 01, 2014, 08:21:11 AM by SohRon »
Offline Oddjob
« Reply #23 on: February 01, 2014, 08:53:17 AM »
There are some points which may be wrong. Just watched the vid and the others are right, brake pedal travel is excessive. I'm not 100% sure but the spline and dot thing on the pedal don't seem to line up, may be one spline out. However even aligning them won't make any difference as all it would do would be to move the brake arm forward but won't move the brake pedal up. However moving the brake arm forward would reduce the amount of travel in the brake action.
The brake pedal adjusting bolt is interesting, in the manual it shows the bolt being fitted the other way, the head is uppermost with the end of the bolt touching the brake pedal, the locknut is against the frame lug. In the parts book it shows it the way you have it. Not sure if that would raise the pedal up a bit, it's mainly there so you can position the pedal to suit your riding position.
SohRons pic doesn't even show the adjusting bolt, unless his bolt is black and is lost against the frame black. That would raise his brake pedal up to it's maximum position which would be misleading. Or maybe the pic isn't clear enough but considering how clean his build is I'd have expected a new bolt which should show against the black frame.
Offline SohRon
« Reply #24 on: February 01, 2014, 08:59:30 AM »
OOps!   ::)   Didn't notice that, but here's another pic that shows the stop nut. I've seen it installed both ways, with the bolt head on top and on the bottom, so I guess Honda isn't quite sure how it goes. Anyway, the pic still shows a higher orientation of the pedal...
