Author Topic: 79 cb750 left switch need help with wiring?  (Read 2542 times)
Offline Wnbasac
« on: January 31, 2014, 12:03:59 PM »
ok i have a 79 cb750 left switch that i want to use but only the signal and horn ( no lights )
i've attached a pic of the switch to see if you can help me identify where the wires go? I tried to follow the wiring schematic but got lost quick. i removed the headlight wiring since i won't be using them.
tks for your help, lou
colors are ;
a. orange
    orange / white strip
b. blue
   blue / white strip
c. gray = power?
d. brown / white stripe
e. light green = ( horn )?
f. dark green = ??
Offline mrbreeze
  • Not your average
Re: 79 cb750 left switch need help with wiring?
« Reply #1 on: January 31, 2014, 03:38:01 PM »
Someone here may have the info you need but this the SOHC forum (pre 1979......cept for the 650 step-child :D and thats only because it's still SOHC)................
MEMBER # 257
Offline cb650
« Reply #2 on: January 31, 2014, 05:16:05 PM »
Going off what I remember from the 650's I have.
The blues and oranges are for the turns I think.
The dark green is the clutch safety switch.
Have to get the diagram to get the rest.
Offline Wnbasac
« Reply #3 on: January 31, 2014, 07:03:14 PM »
Tks guys believe it or not I posted this on the cb750 forum  and they kicked me off cuz I have a cb500...
You guys helped me a lot , not sure how to delete this thread?
Offline LesterPiglet
  • 1977 CB550F2
« Reply #4 on: January 31, 2014, 07:38:56 PM »
Orange and blues are for turn signals. Blue/orange with stripes running lights. Grey flasher unit. Dark green is ground. Brown/white would be gauge lights.The other green/white and green would be the horn.
I would surmise you don't need the wires in bold.
« Last Edit: January 31, 2014, 07:53:16 PM by LesterPiglet »
Offline Wnbasac
« Reply #5 on: January 31, 2014, 09:13:13 PM »
LesterPiglet,
Thank you very much exactly what I was looking for! I'm going to have to get a magnifying glass so I can read those schematics better
Offline mrbreeze
  • Not your average
« Reply #6 on: January 31, 2014, 10:04:13 PM »
OK...........lemme get this straight. You have a 500 but you're trying to use the 79' 750 left switch?
MEMBER # 257
Offline Wnbasac
« Reply #7 on: February 01, 2014, 10:18:26 AM »
Yup your right and I'm not trying I am putting it on my Amen Plunger CB500 Chopper...just thought it was about time to put some blinkers and a horn on it... Way to many Folios on the road these days....
