Author Topic: fuse issues cb750  (Read 1639 times)
Offline Mafia
fuse issues cb750
« on: February 01, 2014, 02:33:31 PM »
So carbs are done. Spark plugs changed. Try to start....no spark. Well was gonna try and find a way to test the coils and plug wires when I opened the small fuse panel and a fuse fell out.seems the posts that hold the bottom of the three ,15amp, are gone. Looks like one side melted out. How do I fix this issue? Doin need a new fuse panel? Good time to upgrade?  Ty
Of all the things I've lost, I miss my mind the most
Offline Mafia
Offline Mafia
Re: fuse issues cb750
« Reply #2 on: February 02, 2014, 08:57:26 AM »
As you can see from the pictures the bottom fuse is melted out.when I took the fuse box off I noticed there is no wires that were hooked up to said position.so even if I get a new fuse box what would that bottom spot run? I am at a stand still fore electrical os not my forte. The only thing that doesn't appear to be working os I have no spark.ty
Offline UncleD
« Reply #3 on: February 02, 2014, 02:31:13 PM »
That's the main fuse and it looks like someone bypassed it. Those twist connectors are not intended for motorcycles. I would recommend sorting out the fuse panel first.
Offline Johnie
« Reply #4 on: February 02, 2014, 05:28:45 PM »
You can always get this nice fuse set up from member Hondaman.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Mafia
« Reply #5 on: February 02, 2014, 06:44:47 PM »
Wow.beautiful. I would love to get that.everything so clean and pristine.my bike sat for 29 years and the only thing left to start is the wiring.
