Author Topic: should I change out my bearings  (Read 1700 times)
Offline HS
« on: February 01, 2014, 05:31:12 PM »
72 CB500 Four.  Low mileage but sat for quite a long time.  I see All Bearings has some nice pieces for the front and rear hubs and the steering?  Should I go ahead and assume I need to swap the stock ones out or?  Bike only has 6800 miles on it but 42 years...
Thanks.
Sam
Offline LesterPiglet
  • 1977 CB550F2
Re: should I change out my bearings
« Reply #1 on: February 01, 2014, 05:41:54 PM »
Yes, no doubt about changing the steering bearings. Probably do the wheels as well as they are cheap.
Offline goldarrow
  • one day, i'll be an
« Reply #2 on: February 01, 2014, 08:08:45 PM »
While the bike is apart, at the very least do the steering bearing, will feel much smoother on a ride.
CB550 K0
Offline Johnie
« Reply #3 on: February 01, 2014, 08:20:51 PM »
I always change out my 40+ old wheel bearings. If you can do it yourself it is a no-brainer for the cost. With the age on them and the fact you can now install sealed bearings go for it. I like the peace of mind when I am traveling at 65 MPH and not having to think about them blowing up on me.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline HS
« Reply #4 on: February 02, 2014, 07:19:11 AM »
Makes good sense, Gents. I was thinking of ordering the All Balls front and rear wheel sealed bearing kits and the steering kit. New front seals for the forks as well. Sound logical and am I missing anything?
Thanks!
Sam
Offline HS
« Reply #5 on: February 02, 2014, 07:22:36 AM »
PS do I need to remove the master link from the chain to drop rear wheel and clean the chain?  I might need to order a replacement link and removal tool.
Sam
Offline goldarrow
« Reply #6 on: February 02, 2014, 07:50:02 AM »
You don't have to undo the chain link if your swing arm is coming off for cleaning.
CB550 K0
Offline HS
« Reply #7 on: February 02, 2014, 08:19:28 AM »
Thanks, GA.  I was not planning on removing the swing arm.  Simply to remove the rear wheel and take a look at the brake drums and replace the rear bearing.  The chain needs a good cleaning also.
Sam
Offline HS
« Reply #8 on: February 02, 2014, 12:18:39 PM »
Thanks for the advice thus far.  Pulled the front wheel and removed the bearings.  Great tips on this thread...
http://forums.sohc4.net/index.php?topic=56044.0
Getting the retainer off was the easy part
Getting the bearing out of the right hand side was another matter.  The heat gun tip is a great one....GREAT!  That and a B.F. hammer (3lb) got it done
I may start a separate thread, but do I need to do anything to service the speedometer mechanism
I'm thinking clean it out lightly and apply some grease...
Thanks.
Sam
  • 1977 CB550F2
« Reply #9 on: February 02, 2014, 02:22:37 PM »
I would clean it out completely using WD40 or similar and regrease.
Offline HS
« Reply #10 on: February 02, 2014, 02:32:09 PM »
and that's why I ask....thanks, Lester.
Sam
« Reply #11 on: February 02, 2014, 03:18:20 PM »
You mentioned the fork seals earlier. If possible the Honda seals seem to hold up far better. The mist important thing to do when replacing those seals is polishing the forks.
They need to be carefully examined and polished. Old time wrenches ran their thumbnail over them and if you could feel it it would cause a leak. They advised polishing any imperfection using extra fine sandpaper using ATF as a lubricant. The sandpaper is used like a shoeshine rag.  After that polish them with Mothers or another polish.
Very minor imperfections you don;t think will polish out, can be filled with crazy glue which will polish very smooth and hold if you clean the spot properly.
This process is a pain in the ass, but, I have gotten 5 years so far out of OEM Honda seal and this process. The "Never Leaks" lasted 2 years.
Offline HS
« Reply #12 on: February 02, 2014, 04:29:56 PM »
Damn, Bobby. That's knowledge...cheers!
Sam
« Reply #13 on: February 02, 2014, 09:49:53 PM »
 I was going to say yes on the wheel bearings. Seems you figured that out already. I just took the wheels off my 8700 mile sandcast. The grease is almost gone, If they could be greased they might last but not dry like this.
Offline HS
« Reply #14 on: February 03, 2014, 06:59:12 AM »
I've got the All Balls front and rear wheel kits ordered. I'm vacillating on the steering and forks....
Sam
  • 1977 CB550F2
« Reply #15 on: February 03, 2014, 09:54:31 AM »
Why the wait on the steering? It's a must. 42 years sitting they are bound to have indents.
You will kick yourself if you put it together and find it doesn't want to turn.
My steering was fine when I stopped riding mine but was as stiff as a stiff thing 20 years later.
« Last Edit: February 03, 2014, 09:56:10 AM by LesterPiglet »
Offline HS
« Reply #16 on: February 03, 2014, 10:10:32 AM »
#$%*...I know you're right.  I grew a pair and ordered the set.
Sam
P.S.  if you're going to order All Balls stuff, go through Amazon...save yourself quite a bit of coin
Offline 750cafe
« Reply #17 on: February 05, 2014, 08:10:16 AM »
Steering head bearing and swing arm bearings are some of the most important bearings to grease as the PO's never do.
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
Offline HS
« Reply #18 on: February 05, 2014, 08:34:22 AM »
Eric
thanks, Eric.  I'm replacing the steering head bearings along with the wheel bearings.  I need to get educated on the swing arm and, in general, how to grease the bike on a maintenance schedule.  Ordered me a grease gun and some red grease but I need to see if I can research how to do this intelligently...I honestly don't have experience with this being a rookie to these bikes.
Sam
Offline 750cafe
« Reply #19 on: February 05, 2014, 09:24:33 AM »
If/when you remove a swing arm, add a grease fitting near the center where you can get to it in the future.
Eric
Offline HS
« Reply #20 on: February 05, 2014, 09:41:48 AM »
Eric
That makes a lot of sense, Eric.
I'm going to look at the manual this week on the swing arm.  I had not planned on removing it, but the bike has sat a very long time and I'm trying to be sensible about getting it back on the road.  to my shock, the grease in the front bearings looked great on this low mileage, 40+ year old bike.  Replacing them was still the right thign to do.
Sam
