Motor is a 74 cb759, with 24k miles, its already apart, and I measured the piston ring gap
With the top ring in the cylinder at the skirt. Measured .559mm. Service limit according to manual
Is .7mm.
My understanding is that I need to hone cylinders, found a shop quote for $100.
The cross hatch is either gone or not showing.
So plan is to hone, and replace rings, circlips, and gaskets.
Bores measure within spec, pistons within spec, only thing that looks questionable is the
Cylinder walls look smooth as glass.
Just wanted to confirm its a good decision to replace rings and hone, for some cross hatch and break glaze.
