Author Topic: CB750 K1 - Twin Disc Set ups  (Read 625 times)
Offline captain rats
« on: February 04, 2014, 01:50:38 PM »
Hey guys,
My K1 front wheel came with two rotors when i bought it(not stock).
Thought i might try to out twin calipers on it and use it. Is there an easy way to do this? Will a later model brake system go on there without much modification?
The K1 fork looks like it has an option on both sides to bolt a caliper but would like to know which brake system to buy that will fit ok.
Thanks in advance and BTW if you have anything for sale to suit let me know
Thanks
Online Rookster
Re: CB750 K1 - Twin Disc Set ups
« Reply #1 on: February 04, 2014, 04:35:51 PM »
http://forums.sohc4.net/index.php?topic=91781.msg1025007#msg1025007
This was for a Lester Wheel but the the caliper bracket and spacing are the same.  The K1 has the early style forks which use the C type bracket.  You need one of those.  The later T type brackets will not fit the K1 forks.
Scott
« Reply #2 on: February 04, 2014, 04:52:18 PM »
Did this on my K8 and used K1 calipers and wheel...
http://forums.sohc4.net/index.php?topic=105018.msg1341362#msg1341362
