Author Topic: Installed spring height  (Read 886 times)
« on: February 07, 2014, 03:38:30 PM »
I got inner valve springs installed and purchased a tool to measure the height.
The problem is, there is no reliable way to measure it. Not within 0.01 mm the specs call for. First of all, the tool is not exactly paralel to the valve stem, second - the screw on the compass is not precise enough to feel the touch, third the installed height is different on each side of the spring.
That said - and experienced - as far as I can tell the springs are right on the upper limit of installed height.  I would rather think it is better to keep them looser/longer since I am not building a racing engine and longetivity is my primary goal.
Or is there a trick I failed to discover?
Please, advise.
Offline tomkimberly
Re: Installed spring height
« Reply #1 on: February 07, 2014, 03:44:23 PM »
I've never heard of measuring installed spring height, just to measure them in the free state, un-installed.
Tom
« Reply #2 on: February 07, 2014, 03:50:11 PM »
What springs? Just use calipers with the depth gauge off the retainer (minus the base)....you'll get within .005 or so easy after subtracting for the base and retainer thickness. And right...set them on the low side.
« Reply #3 on: February 07, 2014, 04:20:46 PM »
CycleX set for F2. The retainer is domed, it was throwing me off. Here are few  pictures of my method.
Thank you, MRieck, will use no shims than.
« Reply #4 on: February 07, 2014, 05:10:04 PM »
Your welcome...yes...no shims at all. Creds for a good build with proper attention to detail. ;)
Offline bytio
« Reply #5 on: February 08, 2014, 12:01:46 AM »
Did you use the cyclex valves?
« Reply #6 on: February 08, 2014, 03:39:04 AM »
Yes, what Cyclex lists for F2 and calls high flow.
Offline tomkimberly
« Reply #7 on: February 08, 2014, 05:26:48 AM »
Thanks guys, I learned something today.  ;)
Tom
