Author Topic: screwed up but good....  (Read 1875 times)
Offline HS
« on: February 08, 2014, 07:28:18 PM »
So I tackle the folks today.  Things were going well.  Got the seal out and look at the fork...pretty grubby looking so I decide to learn how to polish aluminum....check.  Took forever but OK.  So I put the drain plug to the fork that goes in the side, to clear coat the fork after wet sanding and polishing, and without much pressure the damn thing snaps.  I noticed it was tough coming out all the way through it's thread, but the bolt looked find.
Try to tap it and that's when things went to #$%*....
Not my finest day.  I obviously wasn't centered and I went into the threads of the fork.  I drilled through eventually and tried to use an extractor and even that gave in there....tough to drill through.
Thoughts or straight to machine shop?
Sam
Offline boatsdickson
  • 1978 836 K8
Re: screwed up but good....
« Reply #1 on: February 08, 2014, 07:46:12 PM »
Hope yur "folks" didnt mind being tackled as yu stated.  ;D At my confidence and ability I think I would ask the machine shop how they would fix it and then do it myself. Yu have just created a learning experience....no biggie. Sorry not the best answer for ya but on this forum there are far wiser than me and better solutions will be along shortly.
"No. We're all our own prisons, we are each all our own wardens and we do our own time. I can't judge anyone else. What other people do is not really my affair unless they approach me with it. Prison's in your mind. Can't you see I'm free"?  Testimonial of Charles Manson
Offline krusty
« Reply #2 on: February 08, 2014, 07:57:58 PM »
It can be saved but you will most likely need to go up a bolt size. Where the ally has been drilled, is there any of the bolt thread left?
What I would do here (and have done in the past) is carefully file down what is left of the bolt (at about 1 o'clock in the pic) until just before the thread is reached. You can then, using a strong pick of some sort, pull/pry the remains of the bolt thread away from the ally thread. Depending on how deep you went into the ally thread you may need to tap the hole out to next size.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline HS
« Reply #3 on: February 08, 2014, 08:07:17 PM »
Thanks for the response, krusty.  I'm afraid there may be bolt thread left and I may, in effect, have staked the stub of the bolt...not positive.  I had an extractor (relatively thin one but of hardened steel) in there good and the remains of the bolt refused to give.  So when I tried backing out the extractor, the tip gave...I clearly put too much torque on it in hopes of backing out the bolt.
Man I'm pissed at myself right now.
Sam
Offline tomkimberly
« Reply #4 on: February 08, 2014, 09:20:05 PM »
Try a left hand drill, most of the time the screw will just spin out.
Tom
Offline HS
« Reply #5 on: February 08, 2014, 09:45:39 PM »
Tom
I don't have one, but I will tomorrow.  Smart.  Thank you.
Sam
« Reply #6 on: February 09, 2014, 02:48:11 AM »
If it was tough coming out, there may have been an issue previous.
I'd just replace it the lower...
  http://www.ebay.com/itm/Right-Front-Fork-Honda-CB550-CB500-/290846635766?pt=Motorcycles_Parts_Accessories&hash=item43b7cf76f6&vxp=mtr
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=3jvh3mgjicajvqk69i3l908r43&/topic,60973.0.html
« Reply #7 on: February 09, 2014, 02:55:34 AM »
drill the rest parts aut..and cut 8 mm threds..
i hate all this v-w.... vords
Offline Lost and Confused
  • Bob
  • An old fart !!
« Reply #8 on: February 09, 2014, 06:57:06 AM »
Have a set of lowers from 79 750. You can have them free, just shipping.
Bob
Offline HS
« Reply #9 on: February 09, 2014, 07:41:03 AM »
Thanks, Stev-o.  If not joy I might end up with a replacement fork.  I hate the idea of it after going through the sanding and polishing yesterday but it is what it is.
Sam
Offline HS
« Reply #10 on: February 09, 2014, 07:42:47 AM »
Thanks, strynboen.  I'm working on that.  I managed to lose the tip of a hardened extractor in there and my bits are obviously crap.  I'll keep working it today and see if I cant get through and the retap it.  I'll need a proper length bolt, perhaps need to cut one to length.
Sam
Offline HS
« Reply #11 on: February 09, 2014, 07:43:57 AM »
Bob
That's very kind of you, Bob....thanks.  If I get in a pinch, I'll reach out.  I'm hoping I can salvage the fork leg, but with my hands it's 50/50 at best...LOL.
Sam
« Reply #12 on: February 09, 2014, 08:22:39 AM »
I managed to lose the tip of a hardened extractor in there...
Extractors are made of hardened steel, will be very difficult to drill.
FYI - once an easy out is broken in a part, I draw the line on trying to repair.
Offline HS
« Reply #13 on: February 09, 2014, 08:25:12 AM »
I FUBAR'd it, Stev-o.  It'll take carbide bit if at all.  We'll see what the day brings.  Man...
Sam
« Reply #14 on: February 09, 2014, 09:08:25 AM »
Sam
Dont let it get you down, this #$%*e happens when working on 35+ year old bikes.
Knowing the next step to move forward makes a good mechanic.
On a side note, I stripped the damn hard brake line in my K4 caliper yesterday.
What to do?!
Offline HS
« Reply #15 on: February 09, 2014, 12:49:31 PM »
Sorry to hear that, Stev-o.
You were right about the hardened steel....FUBAR.  Screw it...time to move on.
Sam
Sam
What to do?!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #16 on: February 09, 2014, 02:38:18 PM »
With a broken piece of hardened tool steel in there (I've broken both extractors and a taps before) the only way I've been able to clear the hole is with a Dremel and a set of diamond stones. I've also been able to correct an off-center pilot this way as well...
http://www.harborfreight.com/20-piece-18-shank-rotary-diamond-point-tips-69653.html
Plenty of patience too.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline HS
« Reply #17 on: February 09, 2014, 02:46:36 PM »
That's good info there, mad.  Thanks for sharing.
Sam
