Author Topic: Rust Removal From Frame  (Read 770 times)
Offline cb
« on: February 09, 2014, 11:13:20 AM »
I have a 1971 CB500 with many rust spots all along the frame.
Can anyone suggest a good method for rust removal from a frame?
Offline calj737
  • I refuse...
Re: Rust Removal From Frame
« Reply #2 on: February 09, 2014, 06:57:54 PM »
Is the frame bare? Meaning engine out, wiring removed, etc... Or is bike assembled and you want to treat areas you can see while the bike is still assembled?
If it's disassembled, the easiest way is to blast it with glass head, sand, walnut shells, or soda blast media. The latter is cheapest, and easiest to do. You can DIY a soda blast at home. Just use specific blast media, not kitchen grade baking soda.
If it still assembled, saturate the area with WD-40 and scrub with any: tin foil, ScotchBrite pads (green), 0000 steel wool, etc. Many of these pads can be bought as electric drill attachments or to a compressor driven tool. Wire brushes work too, they just make a mess for small areas.
Obviously afterwards you'll need to clean, prime and paint the areas. If you have rust on the frame tubes, that's not a good sign. History on the bike? Some pics would help too.
Offline lucky
« Reply #3 on: February 10, 2014, 06:33:41 PM »
Sand blast and use phosphoric acid then rinse. Paint with in 4 hours. OR just powdercoat it.
It will get sand blasted before powdercoat.
The better places give it a phosphate dip to.
Phosphoric acid turns the iron oxide(rust) into iron phosphate.
It stops the rusting process.
« Reply #4 on: February 10, 2014, 06:58:14 PM »
If you are talking about spots, you can sand them down, use a filler type primer and just paint the frame. Gloss Rustoleum looks pretty original.  Take the money you save and buy something else the bike needs.
