Author Topic: How many of you use the built in auto oiler?  (Read 828 times)
Offline ncstatecamp
« on: February 09, 2014, 07:23:11 PM »
Recently I discovered that these bikes (cb750k, some atleast) have an auto oiler system built into the shaft holding the front sprocket. I was just wondering how many of you used it or just turned it off. I'm not sure what I had mine set to when the engine was in but I cleaned mine by hand ever few hundred miles anyway. Never really had oil fling or anything but it was never too dry.
Offline Davez134
Re: How many of you use the built in auto oiler?
« Reply #1 on: February 09, 2014, 08:26:31 PM »
Disabled mine. Always had a little drip/mess no matter what I did. Also from what I've read, it's the wrong type of oil for chain anyway.  Just plugged it and oil/clean by hand.
Offline bjbuchanan
« Reply #2 on: February 09, 2014, 08:26:44 PM »
I removed the little drip tray during my rebuild, before that I had plugged it up anyway. I'm not one of the super miler's like ofreen or hondaman that actually need to worry about countershaft spline wear.
I also lube my chain up every couple hundred or after a ton of rain (o-ring tho). That oiler was more useful when the recommendation was still to wet the chain down with regular old 10w30 regularly
Offline nccb
  • 1974 CB750 Four
« Reply #3 on: February 10, 2014, 04:25:28 AM »
I plugged mine up when I put an x-ring chain on my bike.  I honestly though the rear hub on that side was supposed to be black until I wiped it down :P
Offline Johnie
« Reply #4 on: February 10, 2014, 05:10:41 AM »
All mine are off and all have the x-ring chain too. Both the KO's came with a full wrap chain guard...evidence the previous owner did not like the oil fling either.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #5 on: February 10, 2014, 05:18:28 AM »
Only on my two stroke RD350, but for the motor, not the chain.
Offline CBGhia
« Reply #6 on: February 10, 2014, 05:32:28 AM »
Are you referring to the leak coming from my oil pump?  It does a good job of lubing the chain on the 550.  ;)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #7 on: February 10, 2014, 06:03:06 AM »
I have the auto oiler just cracked open. Any more than that and the floor looks like I ride an old Triumph.
--Evan
1975 CB750K "Rhonda"
Offline Mini Mo
« Reply #8 on: February 10, 2014, 08:08:01 AM »
Do yourself a favor and read this post. It works like a charm.
http://forums.sohc4.net/index.php?topic=10817.msg101695#msg101695
750 K1 (Just finished)
750 K4 (In Process of resto)
2) 750 K6's (Restored and sold)
750 K5 (Restored and sold)
'75 850 Norton Commando (Restored and sold)
'99 Triumph Tiger (Daily rider)
Offline WhyNot2
  • I'm finally an
« Reply #9 on: February 10, 2014, 05:56:23 PM »
Mine likes to pee down the kick stand......it was off till I screwed with it when changing the sprockets and chain.
