Author Topic: 1975 Honda CB400F Build  (Read 24668 times)
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
Re: 1975 Honda CB400F Build
« Reply #75 on: April 07, 2014, 12:02:44 PM »
Hey if those boots are at all hard, including the ones on the other side, you'd really be wise to do that Wintergreen oil thing and soften them up. . If those won't seal you're going be battling weird running issues and sucking unfiltered air into the engine, etc.
I have a motorcycle problem.
Offline inv3ctiv3
« Reply #76 on: April 07, 2014, 01:03:22 PM »
Any tutorials on that?
1975 CB400F
Offline NobleHops
« Reply #77 on: April 07, 2014, 01:12:52 PM »
7 pages worth!
http://forums.sohc4.net/index.php?topic=62328.0
I found the stuff on Amazon, 4 oz for $20 or so. It's in the thread.
Offline MoMo
  • Ride like you're invisible
« Reply #78 on: April 07, 2014, 05:22:51 PM »
It looks as thought the air chamber may be pushed too far back onto the air filter box...Larry
Offline inv3ctiv3
« Reply #79 on: April 08, 2014, 01:44:31 PM »
I spent almost an hour last night trying to get the stupid carb boots back on and I just can't do it. The outer two I can get but it looks like the airbox is bent inwards a bit which pulls the inner two tubes away from the carbs.....I'm gonna try and take the air filter/box out and stick my hand in there and push it out and maybe hit it with a heat gun while doing that.....
1975 CB400F
Offline MoMo
« Reply #80 on: April 08, 2014, 01:54:09 PM »
Loosen the large clamp that holds the chamber to the box and try to slide the chamber forward
Offline inv3ctiv3
« Reply #81 on: April 08, 2014, 02:59:09 PM »
I did that, it is completely loose and I still can't get the middle tubes onto the carbs....
1975 CB400F
Offline thirsty 1
« Reply #82 on: April 08, 2014, 03:52:39 PM »
Have you tried a heat gun or a hair dryer to soften the boots up.  Then put some sort of boy butter on them and push them over the carbs. Maybe that'll get those suckers to fit.
« Last Edit: April 08, 2014, 04:29:14 PM by thirsty 1 »
Offline NobleHops
« Reply #83 on: April 08, 2014, 07:55:41 PM »
Matt made me LOL
« Reply #84 on: April 08, 2014, 08:01:28 PM »
You 400F guys and your "boy butter."
Offline inv3ctiv3
« Reply #85 on: April 09, 2014, 12:57:23 PM »
Well I got the boots back on the carbs and airbox! Took some heat and force haha. Now I just gotta button up the rest of the bike (put on the new cables, clean rust off clutch lever, put in the Dyna S ignition, etc etc etc)
1975 CB400F
Offline thirsty 1
« Reply #86 on: April 09, 2014, 02:34:32 PM »
Edit
Heat is your friend!
« Last Edit: April 09, 2014, 07:28:07 PM by thirsty 1 »
Offline inv3ctiv3
« Reply #87 on: April 11, 2014, 09:12:31 AM »
It's just one thing after another.....The new clutch cable I got from 4into1 was thicker than the original by a decent amount so when I tried to feed the cable through the actual clutch lever it would fit so I tried to ever so slightly bend it open more and it snapped.....Gotta wait for a new one to get here and it won't be here till Tuesday.
1975 CB400F
Offline bjbuchanan
« Reply #88 on: April 11, 2014, 06:06:28 PM »
If you got the cheaper clutch cable for 10$ it had a disclaimer that it needs filing to fit, that's why so cheap.
File the cheapie or buy the 20$ one
Offline NobleHops
« Reply #89 on: April 11, 2014, 07:26:42 PM »
Same here, had to file it slightly to fit. Hard lesson for you, bit those cable ends are a form of solder I think and soft and easy to shape with a fine file.
Offline inv3ctiv3
« Reply #90 on: April 13, 2014, 09:51:53 AM »
No no no I used a dremel to make the cable end fit, the actual cable itself was too thick to feed into the lever....Like you know how you put the cable end into the hole in the lever and then bring the cable around through the slot in the lever? That slit was too narrow for the cable it'self.
1975 CB400F
Offline inv3ctiv3
« Reply #91 on: April 14, 2014, 10:48:35 PM »
It's just one thing after another with this....I am so close to getting it back on the road but today the battery strap broke due to being old and brittle and now i'll probably have to wait a few days for a new one to arrive and 4into1 doesn't have any in stock so.....  >:(
1975 CB400F
Offline camelman
  • Man... Myth... Legend
« Reply #92 on: April 16, 2014, 12:01:18 PM »
Another trick to get the airbox seated on the two center carbs is to push them on through the rearmost opening on the airbox. I do this by removing the air filter and sticking my hand into the filter housing while holding something to push with such as a screwdriver held backwards so the end of the handle contacts the airbox. It still requires some work, but allows you to press exactly where you need force.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline NobleHops
« Reply #93 on: April 16, 2014, 12:04:20 PM »
This is exactly what I did, worked well.
Offline inv3ctiv3
« Reply #94 on: April 28, 2014, 09:50:13 AM »
Finally got her back on the road! Ugh that took longer than I wanted but it doesn't leak oil anymore and the frame is now patched up! The only thing is it bogs super bad on WOT or high RPM....I have that Dyna S ignition I need to put in and it revs perfectly fine when not under load.....
1975 CB400F
Offline kiwikk
  • Plumbing by Michelotti
« Reply #95 on: May 02, 2014, 01:09:42 PM »
Looking real good  :D
Subtle changes have made sure there's no question it's still a CB400F.
Regarding the Bogging, I'm having the same issue on my recently bought CB400F.
I'm suspecting electrics are my problem (odd plugs and caps + non OEM points) but it's also got a shorter than original new muffler.
Waiting for the rain to stop so I can test it out with it's new plugs, caps and swapped points.
Idles a lot smoother with these.
If this doesn't fix it, I'll be looking at putting the original but grubby exhaust on to test for fuel mix problems.
Opening carbs will be last on my list
Keep us posted on progress of yours
Offline 2strokeTrush
  • Can you get that back together sonny?
« Reply #96 on: May 03, 2014, 09:21:20 PM »
Instagram status ;D
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
Offline Jp from Oz
  • Slowest bike build in history.
« Reply #97 on: May 06, 2014, 03:55:22 AM »
great work mate, I have the exact same bike and am slowly fixing her up. Can't wait to ride it. To say I have learned a little from your thread is an understatement, cheers mate. JP
Offline inv3ctiv3
« Reply #98 on: May 13, 2014, 03:07:41 PM »
Glad I could help! Gonna put my dyna S ignition in this weekend and hope that makes some of the bogging go away, I still want to rebuild my wheels this summer as well but I just want to ride right now.
1975 CB400F
Offline inv3ctiv3
« Reply #99 on: May 18, 2014, 11:13:28 PM »
Welp, installed the Dyna S and now the bike won't start :(
More trouble shooting to do now.....
1975 CB400F
