Author Topic: exhaust  (Read 1157 times)
Offline neilc
  • old school biker,other bike is a 2003 vtx1800c
exhaust
« on: February 11, 2014, 01:47:56 PM »
Question  on my 2into 4 exhaust pipes is their suppose to be exhaust sleeves that go under the clamps,the po was using metal shim stock
Offline Old Scrambler
Re: exhaust
« Reply #1 on: February 11, 2014, 02:29:25 PM »
Always tell us you motor size and model no.  Assuming a K7 or K8 CB750............order the correct parts. New or try the parts wanted page.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline bjbuchanan
Re: exhaust
« Reply #2 on: February 11, 2014, 02:37:25 PM »
750's have two types of mounts. Spigot which is "permanently" attached to the head and you slip the pipe on and clamp it.
Collars and clamp style has collars that sit on the exhaust downtubes and then half circle shims that the collars squish the headpipe to the head by.
I would suggest getting used shims from a WTB, no point in new as they aren't seen
Offline neilc
Re: exhaust
« Reply #3 on: February 12, 2014, 03:54:38 AM »
i have the spigot mount so my finned clamps just slide over the headers but its a pain to take the pipes off and try and slide the shim  stock in then tighten,will think of a better way I usually do
Re: exhaust
« Reply #4 on: February 12, 2014, 04:27:07 AM »
I'm not sure if your clamps won't tighten enough or the pipes are loose on the spigot. If it's the clamps, remove some material off the inside of the non threaded face of each clamp so they tighten further. If the pipes are slack are there four "slots" cut into the end of the tube like a stock pipe? If not do that yourself. They should tighten without resorting to shimming.
Offline toytuff
  • "watching the pinheads"
Re: exhaust
« Reply #5 on: February 12, 2014, 04:39:31 AM »
Here is one style.
tt
Offline LesterPiglet
  • 1977 CB550F2
Re: exhaust
« Reply #6 on: February 12, 2014, 10:36:31 AM »
If it is the above type, put a strip of tape around them when you have them on. Makes things hella easier.
Offline neilc
Re: exhaust
« Reply #7 on: February 12, 2014, 01:23:38 PM »
just checked microphise doesn't show them but it does show something on the pipes a thicker spot on the header,its a 1971 k1 750 model,i guess I will figure something out one way or another,thanks
Offline bjbuchanan
Re: exhaust
« Reply #8 on: February 12, 2014, 01:27:53 PM »
You aren't the first guy with a clamp that doesn't quite grab. One guy used a red bull can as a shim. Like Bwaller said, and I did for my #3, shave the unthreaded portion so it can travel just a little bit more and actually clamp
