Support the site. Your contributions keep this site running.
crankshaft,primary shaft with starter sprag etc,mainshaft needle roller,one or two transmission gears,the kick start mechanism,the sump,oil pump,oil filter housing and bolt,alternator and cover,points/advance unit and cover.
Quote from: dave500 on February 13, 2014, 12:52:12 AMcrankshaft,primary shaft with starter sprag etc,mainshaft needle roller,one or two transmission gears,the kick start mechanism,the sump,oil pump,oil filter housing and bolt,alternator and cover,points/advance unit and cover.^^ Bloody show-off! ^^
