Author Topic: Fork Tube Compatability  (Read 1056 times)
Offline timbo750
« on: February 13, 2014, 06:44:52 PM »
I have been working on getting forks cleaned up and rebuilt and noticed the fork stauntions I have are different than what came out, and no I did buy the wrong ones they came with the bike and the idiot PO (that is now his formal name as far as I am concerned) bought the wrong ones.
The forks on the bike where 69-72 which is actually the only thing so far that I have found on the bike that is 72. The stauntions are from 73-76. I am assuming these wont fit but I thought I would ask as sometimes someone out there knows about a $2 part that allows things to be swapped, hoping to be luck on this one.
Re: Fork Tube Compatability
« Reply #1 on: February 13, 2014, 07:14:13 PM »
Hey Timbo - by stauntion, do you mean fork case? # 16 in the fiche...
http://www.westernhonda.com/fiche_section_detail.asp?section=4326582&category=Motorcycles&make=Honda&year=1972&fveh=190505
If yes, I believe they changed for the K2 model.
« Last Edit: February 14, 2014, 05:58:37 AM by Stev-o »
Offline timbo750
« Reply #2 on: February 13, 2014, 07:59:38 PM »
http://austin.craigslist.org/mcy/4265532363.html
No sorry, fork tube, the terminology seems to vary from country to country on some of these parts and its driving me crazy. the fork lowers or cases seem to be the later model but the internals are the earlier but the diagram on CMS is not that clear. I am thinking I am up for more money.
Offline krusty
« Reply #3 on: February 13, 2014, 08:51:38 PM »
In Oz & UK stauntion/stantion is the top tube "Pipe comp, Fr Fork" - Honda p/list. The lower one is the lower tube or slider or case. Confusing, yes?
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline krusty
« Reply #4 on: February 13, 2014, 08:54:29 PM »
I've a similar, if not the same question. I have a pair of K2 pipes, can I fit them over to F2 cases? The F2 pipes are pretty rusty.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline timbo750
« Reply #5 on: February 13, 2014, 09:27:16 PM »
Krusty, I have a sugestion. I will try to find out if my stauntions will fit the F2 as it sounds like yours will fit mine and then we might be able to trade.
 Have dismantled your forks yet? Photos and measurements might be the best way to check.
Project 1 CB750 - http//forums.sohc4.net/index.php?topic=126864
Offline LesterPiglet
  • 1977 CB550F2
« Reply #6 on: February 14, 2014, 04:24:07 AM »
I use the terms "tubes" and "bottoms", hard to get confused then.   ;) It's spelt stanchion btw.
« Last Edit: February 14, 2014, 04:25:42 AM by LesterPiglet »
Offline Ricky_Racer
« Reply #7 on: February 14, 2014, 11:18:56 AM »
In the same vein as this thread... The F2 front end fork tubes have the same part number as the '77-78K. My question is, is that just because of the longer tubes and, then, will the shorter '73-76K tubes fit the F2 lowers? Thanks! RR
Offline krusty
« Reply #8 on: February 14, 2014, 04:12:56 PM »
I haven't dismantled the F2 forks yet and it could be quite a while before I get to that stage. I have a K series fork set, stanchions and lowers, which I've been hanging on to just in case a K bike came along. So, for the moment, I'm just contemplating options.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
