Author Topic: Help! I can't remove the cam chain sprocket  (Read 797 times)
Offline Jore
« on: February 16, 2014, 05:18:48 PM »
Hi folks, I'm trying to remove the head on 400, as of now I'm stuck trying to remove the cam chain sprocket, every time I try to undo one of the bolts the whole cam turns, so that's my dilemma, is there a trick to tacking those bolts out and not have the whole thing spin around?
Thanks!
1975 CB400F owner
-Having a vintage motorcycle is like having a moody girlfriend.
My 466 build: http://forums.sohc4.net/index.php/topic,146494.0.html
Offline LesterPiglet
  • 1977 CB550F2
Re: Help! I can't remove the cam chain sprocket
« Reply #1 on: February 16, 2014, 05:28:48 PM »
You could engage 5th or 6th gear and lock the rear brake on.
« Reply #2 on: February 16, 2014, 07:26:24 PM »
Yup. If you're by yourself, thread up the rear brake adjuster until it locks the rear wheel, and use a high gear as mentioned.
Offline Jore
« Reply #3 on: February 16, 2014, 09:53:05 PM »
The engine's already out f the bike, can I just use the gears then?
1975 CB400F owner
  • 1977 CB550F2
« Reply #4 on: February 17, 2014, 03:42:51 AM »
Yes,just lock the drive sprocket with some wood or something.
Offline Jore
« Reply #5 on: February 17, 2014, 08:51:47 AM »
Thanks I'll try that
1975 CB400F owner
