Author Topic: What is the length of F2 valves? Do these look worn out?  (Read 1719 times)
Offline banzaibob
« on: February 20, 2014, 06:21:06 PM »
4"?  How much is the service limit?  The faces and seat look good as well as the diameter.  However the end of the stems look as if they may have been beat hard.  In fact, the stem shown was so distorted it had to be chamfered before I could remove it.  The surface of the end shows what looks like small perforations similar to metal transfer.
2011 BMW R1200RT
1976 BMW R90/6
1977 Harley Davidson XLCR
1974 Honda CB750
1979 Honda XR/FT500
1976 Honda CB750F
1971 Honda CB350 Diesel conversion
1976 Honda GL1000
Offline thirsty 1
Re: What is the length of F2 valves? Do these look worn out?
« Reply #1 on: February 20, 2014, 07:41:26 PM »
Toast
Offline thirsty 1
« Reply #2 on: February 20, 2014, 07:42:46 PM »
I'd imagine the adjuster screws are to. Sorry
« Reply #3 on: February 21, 2014, 04:22:02 AM »
Thats what some valves looked like on my F2 head.  Replaced them all.
« Reply #4 on: February 21, 2014, 06:17:03 AM »
I am sure the rocker arm threaded adjuster is equally toasty.
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #5 on: February 21, 2014, 01:06:51 PM »
You mean you had to chamfer the end to be able to pull it through the guide? Wow, never seen one flattened out like that before. Is this a ridiculously high mileage bike? Did the valve stem tips lose their hardness somehow? Metal transfer from the rockers?
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline thirsty 1
« Reply #6 on: February 21, 2014, 08:26:09 PM »
I'd say lack of maintenance. When the rocker has to much valve lash the adjuster screw beats the hell out of the valve stem. Once it gets through the hard face things go south quick.
« Last Edit: February 21, 2014, 08:28:24 PM by thirsty 1 »
