Author Topic: Valve adjuster screws, too far gone now?  (Read 444 times)
« on: February 22, 2014, 08:02:04 AM »
I took these out of the F2 engine, are they too far gone?
Regrind or polish it out?
« Last Edit: February 22, 2014, 08:08:57 AM by 70CB750 »
Re: Valve adjuster screws, too far gone now?
« Reply #1 on: February 22, 2014, 08:10:10 AM »
Those are done and will ruin the valve tips (if you have new valves). They are not that expensive.
« Reply #2 on: February 22, 2014, 08:29:50 AM »
Thank you, I will get a new set - likely from Dynoman unless there is other, better source.
Offline Puntas13
  • '73 cb500 '74 cb750 '09 Triumph Speed Triple
« Reply #3 on: February 22, 2014, 08:38:03 AM »
Whats wrong with them? So I know when to replace mine.
« Reply #4 on: February 22, 2014, 09:18:13 AM »
I believe they are supposed to be lightly domed with hardened surface.
Here is a picture from Dynoman.
« Reply #5 on: February 22, 2014, 12:41:33 PM »
The tips need to be smooth like they are polished and have the same surface geometry.  Files and sand paper have a coarse surface to abrade what they rub against.  You don't want that going on inside your engine.
