Author Topic: Questions about using the NGK splicer  (Read 1166 times)
Offline kingjess25
« on: February 22, 2014, 10:21:39 PM »
When I bought my 1975 cb750, 2 of the coil wires were cut. If I use the NGK splicer, can I use the spark plug wires with boots that they use for cars? or i have to get ones specifically made for these bikes?
Re: Questions about using the NGK splicer
« Reply #1 on: February 22, 2014, 10:34:06 PM »
you mean the caps that click onto the plugs?you must use the resistor type,they have a built in resistor,you can use ngk ones rated at 5000ohms,or 5kohms.
Offline trueblue
« Reply #2 on: February 22, 2014, 10:57:29 PM »
Dave I think he is talking about the little joiners for the coil wires and joining in carbon cored wire.
Kingjess, you would be far better off using copper cored wire with 5K caps.  I'm not a huge fan of those splicers, another join is just asking for trouble.  It's just something else to go wrong IMO. ;D
1979 CB650Z
« Reply #3 on: February 22, 2014, 11:38:20 PM »
i understand that,but i think kingjess25 is talking about the spark plug end?im not keen on joiners either,dont use carbon wire!,i didnt think you could still get it?i thought its all spiral or the old solid now?
« Last Edit: February 22, 2014, 11:41:07 PM by dave500 »
Offline kingjess25
« Reply #4 on: February 23, 2014, 10:27:01 AM »
Yeah, im talking about the ones that hook onto the sparkplugs. I think they're called spark plug caps?
Black 750K8
« Reply #5 on: February 23, 2014, 10:57:48 AM »
Use the NGK that Dave mentioned and solid core wire. I have had the splicers now for about 2 years no problems. I packed the nuts with dielectric grease  just to help keep water out. Z1 has all your needs at a good price and good service.
http://www.z1enterprises.com/ShopByCategory.aspx?name=Ignition&description=Points%2c+condensers%2c+electronic+ignitions%2c+coils%2c+e&category=01010205070207
Offline 750K
« Reply #7 on: February 23, 2014, 11:43:28 AM »
I've got a season of riding with a set of Ngk splices and copper core wires, they work great. No complaints at all.
77 Cb750, 78 Kz1000
Black 750K8
« Reply #8 on: February 23, 2014, 04:12:05 PM »
Would these work?
http://www.z1enterprises.com/ItemDetails.aspx?itemDescription=Dyna+Ignition+Wires+7mm+copper+core+%28red%29&item=DYDW300
Yes and no the wires will work but you will need to cut the ends off and replace them with the NGK 5ohm caps ???
Better to just get the wire buy the foot.
http://www.z1enterprises.com/ItemDetails.aspx?itemDescription=Ignition+Wire+7mm+%28black%29&item=MA8337-1
You only need 4 feet not 8 like they say in there add. If you shop around you can get any color if that matters.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #9 on: February 23, 2014, 04:26:58 PM »
Why won't the wires in the link work? Why are resistor caps needed? I've had standard push on rubber caps for 30+ years and haven't come across a problem yet.
The wires in the link are supplied in pairs that you cut in half. I don't see a mention of length either.
« Last Edit: February 23, 2014, 04:30:29 PM by LesterPiglet »
Offline kingjess25
« Reply #10 on: February 23, 2014, 08:58:41 PM »
So basically I need to buy copper wires and 5ohms caps?
Black 750K8
« Reply #11 on: February 23, 2014, 09:09:03 PM »
Why won't the wires in the link work? I said they will. But not the plug caps.
 This has been explained so many many many times. Look at Honda mans book or look through the FAQ I'm pretty sure TT has a write up about it too.
The wires in the link are supplied in pairs that you cut in half. I don't see a mention of length either.[/quote]
The length I was referring to was from Z1s site. When you buy the wire by the foot. It says 8 feet will do it. But you could do 3 bikes with 8 feet maybe 4 bikes
Were you using resister plugs?
Black 750K8
« Reply #12 on: February 23, 2014, 09:09:52 PM »
Yes
  • 1977 CB550F2
« Reply #13 on: February 24, 2014, 03:45:21 AM »
NGK D7EA
