Author Topic: Bleed screw Swap on a Dual Disc Conversion  (Read 814 times)
Offline timbo750
« on: February 24, 2014, 08:46:02 PM »
I am in the process of sorting parts for the dual disc conversion on a 72 750. on the newly added calliper on the right hand side I would like to change the location of the bleed screw and supply line so its the mirror of the left side rather than the opposite.
I thought I had read about this before but cant find any how to on this topic. It would seem that I would need a new seat for the bleed screw relocation and I would assume that the old one can't be removed. If I am right then I would have to either source the seat or get one made.
can some one point me in the right direction please.
Offline timbo750
Re: Bleed screw Swap on a Dual Disc Conversion
« Reply #1 on: February 25, 2014, 06:27:41 PM »
Anybody?? I have seen pictures so I know it can be done.
« Reply #2 on: February 25, 2014, 07:54:39 PM »
You simply remove the flare seat and re-install it in the other hole.
I have threaded a sheet metal screw into the seat, then pried it straight out using needle-nose pliers between the caliper body and the underside of the screw.
Offline timbo750
« Reply #3 on: February 25, 2014, 08:55:35 PM »
Scottly, thanks I figured considering I could not much info it would be simple but had to ask to make sure I didn't stuff it up.
Project 1 CB750 - http//forums.sohc4.net/index.php?topic=126864
Offline Whaleman
« Reply #4 on: February 26, 2014, 04:13:39 AM »
I have cut a finish nail to go up from the inside and was able to grab it with a plier and pull out. Dan
« Reply #5 on: February 26, 2014, 04:32:58 AM »
For my dual disc I took the flare seat out and left it out.  Works fine without it.
