Author Topic: Don't use paint stripper on headlight shell (probably side covers too)  (Read 5796 times)
Offline Garage_guy_chris
I had some misfortune today trying to clean up an old headlight bucket. Initially i used a methylene chloride based stripper and it really softened up the plastic, i tried a milder citrus stripper and it was better but still softened up the plastic. I suspect original side covers may suffer the same fate, but Im not sure because i have never seen an original one and am not familiar with the material.
Anyways just a heads up so no one screws up any parts.
Offline LesterPiglet
  • 1977 CB550F2
Re: Don't use paint stripper on headlight shell (probably side covers too)
« Reply #1 on: February 25, 2014, 03:25:22 PM »
Never use stripper on any plastic. It's not needed anyway. You only need to strip paint to clean up rust really. I've never completely stripped the paint of anything to repaint. Primer covers it.
« Reply #2 on: February 25, 2014, 03:27:30 PM »
If you do it quickly, use some spray paint thinners on a cloth and just wipe off the old paint, like I said, do it quickly and you won't hurt the plastic... ;)
fendersrule
« Reply #3 on: February 25, 2014, 03:28:52 PM »
Yep. I've used Lacquer thinner (or was my Acetone?) to clean out some over spray in my bucket, but it was distributed on my rag first and then wiped and dried quickly.
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #4 on: February 25, 2014, 03:29:17 PM »
Thank you for sharing your hard-won lesson. I might have tried that, not thinking, and you may have saved me and others from  also learning it the hard way. Much appreciated.
I have a motorcycle problem.
Offline Geeto67
  • A grumpy
« Reply #5 on: February 26, 2014, 04:10:43 AM »
There are plastic safe paint stripers. I forget the brand but I used to buy the stuff when I was really into plastic car models. I would buy unfinished badly painted discontinued kits and soak them in this stuff I bought mail order.
I have heard simple green and purple power do the same thing, but if you leave the plastic in too long it can damage it. Someone recommended something called Dettol (which is a household disinfectant) to me as plastic safe.
Maintenance Matters Most
  • 1977 CB550F2
Offline MoMo
  • Ride like you're invisible
« Reply #7 on: February 26, 2014, 04:23:37 AM »
Geeto67 is right on the mark.  I do not know the brand either but I do know plastic safe strippers exist, most likely source would be a shop the supplies to body and fender shops. ...Larry
« Reply #8 on: February 26, 2014, 09:42:56 AM »
+1
scuff. prime. sand. paint.
« Reply #9 on: February 26, 2014, 11:19:32 AM »
.... Initially i used a methylene chloride based stripper........
That's really good stuff no longer available. Methylene chloride probably not allowed due to ozone layer or...?
That attacked 2 component glue, paint very quick. Bare metal within minutes....sometimes seconds...
30 years ago I had access to it at my job. I brought home a liter or two when needed.
Same with Hermetite Golden, very good sealer for crank case, o-rings, under cam towers. It had the good stuff Methylene chloride.
Headlight buckets are for sale, not that much money. CB750 has chromed version too, not only OEM Black. K0-K1 have same color as the tank, side covers.
« Reply #10 on: February 26, 2014, 11:34:02 AM »
+1
+2    Stripper not needed or desired for motorcycle plastic parts.  Layers of well adhered paint actually make a very good under base, particularly for UV resistance.
But, that usually won't stop people from doing it anyway.
The plastic in this case is ABS  or  Acrylonitrile Butadiene Styrene
You can find what chemicals it is resistant too here:
http://www.rtpcompany.com/technical-info/chemical-resistance/
Or Here:
http://www.coleparmer.com/Chemical-Resistance?referred_id=11033&mkwid=sJFDnHw4J&pcrid=12430988319&kw=%2Bchemical%20%2Bresistance%20chart&mt=b&pdv=c&gclid=CM3m4sPC6rwCFYlafgodb3wAMg
Or, you can do a google search for ABS plastic paint stripper.
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #11 on: February 27, 2014, 07:46:06 AM »
i have a friend who dated a plastic Stripper for a while. Emptied his wallet and his heart.
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
Offline Geeto67
  • A grumpy
« Reply #12 on: February 27, 2014, 08:58:26 AM »
+1
That may work for a plastic part with three or less layers on it but I have side covers in my sidecover bin with paint so think on them that I think it is actually thicker than the plastic itself. I have headlight shells to match. Plus what if you are doing a restoration and you are worried about sanding off the extruded plastic parts numbers and mold marks some of the headlight shells have (side covers usually have an inkstamped part number on the back side if they are a replacement part)? Again, there is a tool for every job and sometimes that is sanding and sometimes it's throwing the part in a tub to to soak in chemical for 24 hours.
« Reply #13 on: February 27, 2014, 09:06:39 AM »
ALL plastic, or just certain parts of her were?  :o ;D
  • 1977 CB550F2
« Reply #14 on: February 27, 2014, 09:09:40 AM »
Who paints the back of a plastic part that was unpainted in the first place?
If you use a paint stripper those small prominent parts will be the easiest and first to be melted.
Offline Geeto67
  • A grumpy
« Reply #15 on: February 27, 2014, 09:43:04 AM »
The same people who paint the underside of tanks when doing a custom paint job. Some do it, some don't.
Offline MoMo
« Reply #16 on: February 27, 2014, 12:04:46 PM »
"plastic fantastic lover"  The Airplane
