Author Topic: Fitting a muffler - CB550F 4 into 1  (Read 889 times)
Offline Texas Ty
« on: February 25, 2014, 03:46:11 PM »
Ordered a 17" reverse cone muffler from Dime City and am having some trouble installing. The front end of the muffler is smaller than the 4 into 1 mounting spot on the original exhaust. The kit came with three sleeves but I believe those would be used if the muffler was too large rather than too small. Any ideas? I do have access to a welder and could fab something but was gonna see if any of you guys have had luck installing these in a simpler way.
Cheers
Ty
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: Fitting a muffler - CB550F 4 into 1
« Reply #1 on: February 25, 2014, 03:59:02 PM »
I did that exact thing. I have a 77 CB550f and installed an aftermarket muffler. I went to an auto parts store that sold exhaust adapters and found one that would slide over the header and into the muffler. The only concern is that the adapter is not chrome, but I sprayed it with silver high heat paint and it looks good.
..........Paul
Offline calj737
  • I refuse...
« Reply #2 on: February 25, 2014, 04:39:04 PM »
To 05c50s point: use an exhaust reducer from the collector on the header that fits into your muffler. If at all possible, weld the reducer to the collector to insure leaks are prevented. The muffler can be clamped or welded based upon your preference.
Reducers tend to be pretty thick metal and are difficult to clamp sufficiently and often leak.
Another option: go to a muffler shop and have them weld an extension on should you need more pipe length to fit/angle your muffler if the attachment is not to your liking.
Offline Texas Ty
« Reply #3 on: February 25, 2014, 08:48:11 PM »
Thanks y'all. Gonna hit the auto parts store and see about buying an adapter to weld on.
Offline jonda500
« Reply #4 on: February 26, 2014, 01:45:05 AM »
My muffler was smaller than the diameter at the end of my 4 into 1 too- I got a piece of 2 1/4 inch pipe with a 5 degree bend in it from the muffler shop - I rammed the muffler into this pipe and welded it on, then I welded it straight to the end of my 4 into 1.
   I am considering braising over the welds and smoothing then polishing the brass so the oxy welded joints can't rust.
A starter clutch thread:
