Author Topic: How to split the cases.... '77 CB550F GOT IT!!!!!  (Read 383 times)
Offline dagersh
    • Photos
« on: February 25, 2014, 04:24:05 PM »
Hi Guys,
I have hit that point on the rebuild, I am ready to split the cases.  I have all the fasteners out, but I have not removes the oil pan.  The block is on my table, and I don't want to turn it upside down as the rods are proud of the upper case.
I tried some good hits with a rubber mallet, but no dice.....
I did some searching here, and I am wondering if I need to remove the primary shaft first?  As I understand it, the CB400's need this before the cases can be separated.
Thanks!
Gersh
« Last Edit: February 25, 2014, 04:55:09 PM by dagersh »
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline calj737
  • I refuse...
Re: How to split the cases.... '77 CB550F
« Reply #1 on: February 25, 2014, 04:28:42 PM »
Are you  he splitting your 550 or a 400? The 550 oil pan does not require anything more than the 10 pan bolts to be removed to allow the pan to come free.
Some whacks with a rubber mallet all the way around the perimeter should get it free, unless a PO used some sealant. That may require a bit of prying carefully with a hard plastic spatula and some whacks.
Offline dagersh
    • Photos
« Reply #2 on: February 25, 2014, 04:54:40 PM »
Calj
Got it.  One bolt under the oil pan!  OOOOOPS
Advice on a 400 came up in a search.
Thanks Bro!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline calj737
  • I refuse...
Re: How to split the cases.... '77 CB550F GOT IT!!!!!
« Reply #3 on: February 25, 2014, 05:13:49 PM »
Always helps to count the number of screws. Makes it easier to get the covers off :-)
Funny, the little victories in rebuilding these machines make it all worthwhile!
