Author Topic: Grease gun  (Read 3763 times)
Offline luckysox
Grease gun
« on: February 25, 2014, 09:02:05 PM »
  I didn't know where to post this . Where can we buy the right grease gun fitting to use on the swing arm pivot bolt .  Thanks
Offline scunny
  • don't call me expert
Re: Grease gun
« Reply #1 on: February 25, 2014, 09:41:44 PM »
remove the "zerk" fitting and replace with a grease nipple.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Untold
Re: Grease gun
« Reply #2 on: February 26, 2014, 06:29:29 AM »
I got a cheapo one from harbor freight that works fine.
1976 CB550K
Offline bjbuchanan
Re: Grease gun
« Reply #3 on: February 26, 2014, 01:39:00 PM »
You could post this in regular tech section. Just remove what is in there and thread in a "normal" fitting so any grease gun will work. Much more economical
Offline luckysox
Re: Grease gun
« Reply #4 on: March 05, 2014, 09:55:29 AM »
  The original fitting is NOT a zerk fitting . I have the same fittings on steering damper joints , only smaller . This is what I am referring to . They are too small to change out . Any help
« Last Edit: March 05, 2014, 03:25:38 PM by luckysox »
Offline bjbuchanan
Re: Grease gun
« Reply #5 on: March 05, 2014, 11:36:01 AM »
We already told you that. Take it out and tap for a real fitting.
In the mean time post in a real section
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=mckufvimgjsjtobutip59rd1c4&/topic,60973.0.html
Re: Grease gun
« Reply #6 on: March 05, 2014, 11:48:49 AM »
all truck/ tractor/garden machine sales have this stuff
..there is threds in svingarm..to schrev  a standart fitting in..the steering damper have a press in type fitting..but can be cut thredet/or find a press in fitting..there are some standart in this.types so it easy to find a fit..
i hate all this v-w.... vords
Offline luckysox
Re: Grease gun
« Reply #7 on: March 05, 2014, 01:21:05 PM »
        And what section is that ?  Do you have a source for a Zerk fitting this small ?   How do you get the chips from drilling and tapping out of a sealed fitting ?  I have about 40 of these to grease and would not be reasonable to change that many fittings, rather than get the correct grease gun fitting .  Would a Moderator please move this to the correct Section as  BJBUCHANON  doesn't think it should be here .
Black 750K8
Re: Grease gun
« Reply #8 on: March 05, 2014, 04:36:23 PM »
 "I have about 40 of these to grease"
You have 40 swingarms? :o :o :o :o
@ bj I have to admit I don't know what you mean by a " real section"? The correct form maybe?
 "How do you get the chips from drilling and tapping out of a sealed fitting ?"
It has to be taken apart any way to clean it up and get the 30 year old dried up grease out and put in new bushings.
@  luckysox Take the swingarms all 40 of them and strip them down. Drill and tap for new standard US zerks. Grease it up and put back together and from then on you can use a standard grease gun. Got it. :)
Are you going into the swingarm rebuilding business like Hondaman?
Offline bjbuchanan
Re: Grease gun
« Reply #9 on: March 05, 2014, 07:46:46 PM »
The posting has been in wtb section for a while, that is what I meant by move it. I could have ignored the post totally like plenty did, I was hoping a mod would move it.
Luckysox, what I said to do is what 750k8 said, and what we will all say. Take the oddball jap grease fitting out and replace with a standard US.
That jap grease fitting is obscure, haven't heard of anyone actually sourcing the fitting
Offline Fatlip
Re: Grease gun
« Reply #10 on: March 05, 2014, 11:21:01 PM »
Just buy one of the needle tips and stick it in the middle of the old one.
http://www.grainger.com/product/LINCOLN-Nozzle-6Y900?s_pp=false
Offline luckysox
Re: Grease gun
« Reply #11 on: March 22, 2014, 06:10:53 PM »
        If somebody had a nice Sandcast, would you tell him to change fittings on it ? The post was in the wrong section for a total of 8 days before you ranted for it to be moved . The fittings are on steering dampers  but are the same as the swingarm fitting only about have the size . There is NO way too take them apart to clean out chips .    Thanks Fatlip for at least a reasonable suggestion
Offline SohRon
Re: Grease gun
« Reply #12 on: March 22, 2014, 08:53:42 PM »
This is all you need to use the stock zerks. No need to replace them, just use the right grease gun!
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
Re: Grease gun
« Reply #13 on: March 22, 2014, 09:47:03 PM »
Wow....I did not realize there was a "right" grease gun.  I have been pumping grease into mine with a regular old grease gun with a flex hose for years.  I just hold it on the fitting real tight and pump.
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
Offline SohRon
Re: Grease gun
« Reply #14 on: March 23, 2014, 07:21:08 AM »
OEM Honda zerks, right?
Congratulations on having such strong fingers, but I think you're in the minority! I think the main reason most folks replace their stock zerks is because they can't get their flex hoses to work on the originals. The rigid pipe helps hold the nozzle firmly against the OEM zerk.
In fact, most grease guns come with both a flex hose and rigid pipe extension. Even you may benefit from fitting the rigid pipe!  :D
« Last Edit: March 23, 2014, 07:52:17 AM by SohRon »
  • Butch
Re: Grease gun
« Reply #15 on: March 23, 2014, 08:15:51 AM »
I gots me them strong fingers LOL.  But I have a rigid pipe, a pneumatic gun that I seldom use and even an old mini grease gun that you can hit with a hammer if you want too....just have never needed them.
750 K5
550 K1
Black 750K8
Re: Grease gun
« Reply #16 on: March 23, 2014, 07:50:21 PM »
That is the type most often used on a chain saw.
Offline Deltarider
Re: Grease gun
« Reply #17 on: March 24, 2014, 12:58:33 AM »
Is there a way to prep the nipple, by prudently sticking a thin pin in its hole and move it a bit?
CB500K2-ED Excel black
