Author Topic: Cb500 Calliper Pin  (Read 818 times)
Offline MickB
Cb500 Calliper Pin
« on: February 25, 2014, 10:17:02 PM »
Can someone explain how the calliper pin holds the brake on?
Also, will the calliper from a '72 500 twin fit onto a '72 cb500 Four?
Offline jonda500
Re: Cb500 Calliper Pin
« Reply #1 on: February 26, 2014, 01:17:09 AM »
the inner pad has a split pin - to retain the brake pad in the calliper's inner piece the pin is threaded through from the pad side and the ends folded over on the outside of the calliper piece.. if you didn't mean this pin you may need to post a photo of your problem
my cb500 four has a caliper I removed from a twin- looks exactly the same, fitted no problems and works fine
A starter clutch thread:
« Reply #2 on: February 26, 2014, 02:12:09 AM »
the split pin is an assembly aid,holds it to the back plate as you install it so it doesant fall out,they have a roll pin to stop them rotating that locates the pad,i use a dab of silicon sealant on the back to stop it vibrating in place,same on the piston side pad.
Offline MickB
« Reply #3 on: February 26, 2014, 12:55:23 PM »
Thanks guys
Offline MoMo
  • Ride like you're invisible
« Reply #4 on: February 26, 2014, 01:23:14 PM »
Is a 72 500 twin an Aussie thing?.  The 450 wasn't converted to 500 in the US until 1975...Larry
« Reply #5 on: February 26, 2014, 08:48:33 PM »
we met a bloke a few weeks ago with a 500 twin,it was an american import,i dont think we got it here?
Offline jonda500
« Reply #6 on: February 27, 2014, 04:08:00 AM »
I can recall seeing DOHC 500 twins here(I noticed them because I owned a 450). Many, many years ago I saw one for sale for $1600 at a bike shop here in Canberra - and from memory I do think it was an earlier model than '75 ..
Offline LesterPiglet
  • 1977 CB550F2
« Reply #7 on: February 27, 2014, 06:00:51 AM »
We didn't get them until 75-76 in the UK.
