Author Topic: 74 750 signal configuration (1 or 2 wires??)  (Read 503 times)
Offline Garage_guy_chris
« on: February 26, 2014, 08:27:51 PM »
Hello everybody i have another dumb question about my 74 750. The PO removed the signals and all the associated wiring. While shopping for OEM/reproduction signals I have noticed there are 1 wire single filament and 2 wire dual filament signals. Im not sure what the original signal configuration was. im curious before i place any orders for them
-What years use the smaller signals?
-What is the configuration for the signals front and back (number of filaments or wires)
-Obviously one filament is for the flasher signal if using dual filaments whats the other one for? Running light, brake light?
Thanks again
Offline mrbreeze
  • Not your average
Re: 74 750 signal configuration (1 or 2 wires??)
« Reply #1 on: February 26, 2014, 08:45:30 PM »
They went to the bigger lights on the 75 model. The 75 has dual filament in front (running light & turn). The rear is just turn. Not 100% sure if pre 75' was the same. A wiring diagram will show it.
MEMBER # 257
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: February 26, 2014, 10:24:13 PM »
orange wire for left ts, orange/white for left running light.   light blue wire for rt. ts, light blue/white for rt running light.  If you have those wires in your headlight shell then you had the larger signals.  Rear signals were single filament only...Larry
