Author Topic: New Clamps for Carb Boots & Airbox  (Read 1564 times)
Offline AintNoEasyWay
« on: February 27, 2014, 05:41:23 AM »
Hi everyone, looking for a tip on clamps for the boots & airbox for my CB750 K7. Are the clamps for the boots to the carbs the same I'll need for those coming from the air box "boots" (not sure if these are called boots as well)?
I ordered new clamps (size 45-49mm) from Parts N More, but the clamps they sent me are over 52 mm when fully closed & won't work.
I found a thread that recommended Carpy's clamps (http://www.cb750cafe.com/products-page/hardware-clamps/stainless-steel-hose-clamps/), but not sure if these will work on my K7 as well.
Appreciate any info you guys can give me!
Black 750K8
Re: New Clamps for Carb Boots & Airbox
« Reply #1 on: February 27, 2014, 05:54:18 AM »
45-49 is correct they sent you the wrong ones. I got mine from DSS they have great stuff and good service. I have a 78 so they are the same. I'm sure carpys is good as well.
Black 750K8
« Reply #2 on: February 27, 2014, 06:01:33 AM »
Also I would not use the worm drive clamps from the auto parts store. The notches dig in and cut the rubber over time. Did you know you can get new carb insulator 1-4 now? You can get the clamps from Honda too.
« Last Edit: February 27, 2014, 06:04:04 AM by Black 750K8 »
« Reply #3 on: February 27, 2014, 06:15:40 AM »
Black, thanks for the reply. What do you mean carb insulator?
Black 750K8
« Reply #4 on: February 27, 2014, 06:19:47 AM »
That is what the rubber boot between the carb and engine is called where the clamps go. 8,9,10,11.
http://www.cmsnl.com/honda-cb750k8-four-usa_model14397/partslist/E02.html#results
« Reply #5 on: February 27, 2014, 06:26:48 AM »
Oh yea, very cool. I knew I read those were unavailable for a long time. Thanks for that tip too!
Black 750K8
« Reply #6 on: February 27, 2014, 07:18:40 AM »
This is the place that has the insulator set (carb holders) and they have the correct clamps too. I bought a set to try out they look exactly the same now to see how the rubber compound holds up? Honda still has # 1&3 the last time I checked. 77-78 750K are the same.
http://www.vintagecb750.com/products/6/fuel-system/54/carb-holders-clamps
« Last Edit: February 27, 2014, 07:22:25 AM by Black 750K8 »
« Reply #7 on: February 27, 2014, 07:45:32 AM »
Nice. Fortunately my insulators are in decent shape. But I did have to buy new boots for the air box, which I got from vintagecb750.com.
