Author Topic: Looking at getting a new master cylinder for my cb500. Suggestions?!  (Read 1074 times)
Offline Maximiliaanvk
Hi everyone,
I need to get a new master cylinder for my CB 500 1972. I want to keep the same calliper and system. Just want a smaller master cylinder so it will fit on my handle bars. Currently its all a bit too big and won't really fit.  :-[
I was looking at spending as little as I could with having some sort of an upgrade. around $100 would be fine and second hand doesn't bother me.
An suggestions on what could work for me? I have been looking and can't find any replacements that will definately work with my current system which is connected to the bottom triple tree. Please help! :o
Thanks.
Max
Re: Looking at getting a new master cylinder for my cb500. Suggestions?!
« Reply #1 on: February 27, 2014, 12:05:37 PM »
You can get a brand new 12 or 13mm Brembo for $120 and they're quite small. Nice master.
https://store.bevelheaven.com/brake-related-parts/12mm-rec-brembo-master-cylinder-front-brake/
Offline faux fiddy
  • bike in a box
« Reply #2 on: March 03, 2014, 09:12:53 PM »
Can you post a picture? Some older BMW bikes (and I'm sure others) use a remote MC that tucks under their tanks. That type may well work for you too.
My friends 254 guzzi has a cable to a mc and reservoir under the tank.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline jamesb
« Reply #3 on: March 03, 2014, 09:57:56 PM »
I think some guys use the Ducati style reservoir they are small amazon has them cheap.
Offline Seeparkfly
« Reply #4 on: July 29, 2014, 02:27:36 PM »
How does the braking power compare to a radial master cylinder? I'm in the hunt for a new MC and want to max out the stopping power on these old hondas with a single rotor (ground and drilled).
