Author Topic: frayed wires inside case that covers drive sprocket  (Read 892 times)
Offline Chaser60
  • 75 CB550
« on: February 27, 2014, 03:53:39 PM »
Wondering if any of you have encounter this little issue.   As you can see in the pics (sorry they are a bit blurry), there is some pretty strong wear on the outer sleeve of the wire bundle and also on a couple of the wire insulators as well.   I know I need to replace this, but any idea how this was caused?  Is there a wire attachment point that maybe was not attached?
Is best fix (reliable and not a fortune) to simply replace the bad wires in the harness?
Thanks
