Author Topic: Working Toward First Start 78 CB550, Started! - Videos Added  (Read 3292 times)
Offline jason405
« on: February 28, 2014, 12:47:02 PM »
Hey Guys,
so I am in the early stages of my first bike project. It's a 1978 CB550K and at this point I am working toward firing it up for the first time.  It has sat for 3 years since it was last ran.
I want to use this thread for help with the random things I need to do to it before trying to start it for the first time.  Once I get it running and have faith that I can build a nice bike out of it, I will close this thread and start an official project thread.
The first thing I did was a full carb rebuild and I am finishing that up right now.  My dedicated thread on the PD46C carb rebuild can be found here: http://forums.sohc4.net/index.php?topic=133559.0
The next thing that needs to be addressed before trying to fire it up is the tank.  It had a nice rust line about 1.5 inches up from the bottom where gas/water has obviously been sitting for a couple years. I noticed small bubbling spots in the paint when I first got it, and knowing I was going to repaint the tank anyway, I scratched at those posts and sure enough, out comes nasty 3 year old gassy sludge.
So I have stripped the tank and identified several more small holes. I plan on putting a liner in it, but decided I wanted to fix it the best I could so I took it to a radiator shop where they soldered the holes shut, streamed out the inside, and pressure tested it to 10psi with no leaks.
At this point I am ready to pick a liner to put in it. I know there could be other weak areas in the tank so I would like to use a liner that not only seals, but also is known for being able to fill small holes if there happens to be any more show up, and help reinforce the walls of the tank. That is where I would love to here what you have to say.
I have narrowed it down to these three:
1. KBS Tank Sealer Kit http://www.kbs-coatings.com/cycle-tank-sealer-kit.html  I like the price and I like that it comes with other cleaners to help get the best adhesion. I have heard nothing but good about this stuff.
2. Caswell Epoxy Liner http://www.amazon.com/Caswell-Epoxy-Tank-Sealer-Motorcycle/dp/B001PLM5TC  Seems to be known for being able to seal fairly large holes and can be mixed with pigment to be able to see any missed spots in the tank.
3. POR-15 Liner http://www.amazon.com/POR-15-Cycle-Tank-Repair-Kit/dp/B000H9K4JQ  Seems best for adhering to tanks in the worst shape, but seems hit or miss on durability.
I am really leaning toward the KBS kit, but I am not completely convinced it will seal AND add a layer of physical protection around weaker areas like the other 2-parts might.
I would love to here your thoughts on using these liners in my situation to help me figure out which one to order.  I understand, in any case, the tank MUST be completely dry.
Sorry for the long post.  I will post pics of the tank asap.  Once I get tank sealed, I will be really close to being able to fire it up I think, but one thing at a time ;)
Thanks!
Jason
« Last Edit: April 12, 2014, 08:10:38 PM by jason405 »
Offline jason405
Re: Working Toward First Start 78 CB550
« Reply #1 on: March 01, 2014, 01:13:02 PM »
Got my tank back from the radiator shop.
Ok, after doing some more reading, I think I have decided on POR-15.  Going to order the kit and hopefully knock it out next weekend.
Here are some pics of the tank. There is bondo and skim coat left bind that I am going to leave and I will have to add more bondo where the radiator gut brazed some holes shut.
Offline rb550four
« Reply #2 on: March 01, 2014, 02:27:13 PM »
Cool. Are you going to remove the rest of the rust from the tank before sealing it? There is a bunch of ways/products to do that.
here 's just one thread, I'm sure there is more on the subject in other threads on the search bar
http://forums.sohc4.net/index.php?topic=91545.0
  if interested.
What's the rest of the machine look like?
Offline jason405
« Reply #3 on: March 01, 2014, 03:57:33 PM »
I'll post some full body pics soon!
The radiator guy steamed out most of it. The rest I was just planning on attacking with the prep & ready that comes with the POR-15 kit.
I will also be on the hunt for a new petcock. Not 100% sure, but I think the one that was on it is done. Any good ways to test it besides just on the tank?
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #4 on: March 01, 2014, 04:09:37 PM »
POR-15 is good stuff! You made the right choice with it. Just make sure you follow the directions to a "T".
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline jason405
« Reply #5 on: March 01, 2014, 06:00:27 PM »
Great! planning on doing just that!
Here is the bike when I got it. It was last ridden in 2010. Bike is pretty clean but the motor is pretty dirty. Oil/dirt mix on the outside. Going to hit with foaming degreaser, then pressure wash it. And that exhaust has got to go. I dont know to what but I'm not loving the current setup. Seat is stock and in PERFECT shape! Not planning on keeping it though so it will be up for grabs at some point.  Carbs off for rebuild, and some electrical taken down.  Tank was painted somewhere along the way. Come to find out, that was most likely due to some denting given all the bondo I found under the "custom" paint job lol.
Planning on building my own wiring harness. Thought is to keep electrical minimal. All LED lights besides an HID up front.
I'm trying to spend as little money and do as little work as necessary before getting her to run.  That way I'll know I have a good base to work off of.
« Last Edit: March 01, 2014, 06:06:48 PM by jason405 »
Offline jason405
« Reply #6 on: March 03, 2014, 07:52:00 AM »
Alright so the carbs are done!
Next is sealing the tank and engine prep.   While waiting on the sealer kit to arrive, I would like to get started prepping the motor.
My thought was to drain oil and drop the pan and clean it out.  Then replace the filter and fill with fresh oil. I have new spark plugs to be installed and I figured I would check the valve clearances.
Does this sound sufficient before attempting a first start in 3 years?  Can anyone offer a cleat course of action that would be better?
Thanks!
Jason
Offline calj737
  • I refuse...
« Reply #7 on: March 03, 2014, 09:25:55 AM »
Dropping the pan and an oil swap is prudent. Before you pop in new plugs, shoot some penetrating lube into the cylinders and make sure the cylinders are nice and wet. This too may aide in freeing up anything that has gotten "sticky" in there. if the motors spins freely, add plugs and fuel to fire.
A little prevention can save you heaps later. With the plugs out, motor should spin more easily as an added benefit.
Offline dagersh
    • Photos
« Reply #8 on: March 03, 2014, 09:38:54 AM »
Jason,
Run through a complete tune up as per the Manual.  Definitely check valve clearances, timing and cam chain tension.  After you change out the oil, be sure you have good flow from the oil pump, you can do this by spinning the starter motor with the kill switch off and checking for flow through the tappet covers.  It also primes the system, so it is oiled up when ready to start.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline jason405
« Reply #9 on: March 03, 2014, 10:30:24 AM »
Thanks guys!  It kicks through just fine right now but a couple drop of marvel mystery oil through the spark plug holes would be a good idea still right?
Gersh,  I will do the tune up per the manual for sure, and will remove the outer tappet covers to ensure oil is making it up top just before attempting to start the first time.
Thanks for the info guys! Will report back once I am ready to start to double check everything.
Jason
paul_D
« Reply #10 on: March 03, 2014, 06:51:43 PM »
If you are dropping the oil pan, check that the primary chain is still tight and not slapping the oil gallery. Too much slack from the primary will chew through the oil gallery and you'll loose all oil pressure and be looking for a new bottom case.
Offline jason405
« Reply #11 on: March 03, 2014, 08:37:41 PM »
Thanks Paul! Is there some speck for the tension of that chain? I haven't look in the manual yet. Just curious if you knew off the top of your head?
Thanks!
Jason
paul_D
« Reply #12 on: March 03, 2014, 08:54:02 PM »
I couldnt find any spec's but I have some pictures.. I think its clear which is the new and which is the old primary chain.  You can see the damage the old one did to my case.
The old chain slipped off easily, the new chain was snug.
If you do decide to change the chain, just know you are in for a huge overhaul tearing the whole engine apart.  But if the inside doesnt look/feel worn like my image, you should be fine.
paul_D
« Reply #13 on: March 03, 2014, 08:55:41 PM »
BTW, that image is a top down view, you would have a bottom up view going through the oil pan so it would be by feel. the primary chain is at the front of the case linking the crank to the transmission.
Offline jason405
« Reply #14 on: March 03, 2014, 08:56:02 PM »
Absolutely. I have ZERO desire to crack the cases.
Let's hope it looks acceptable!
paul_D
« Reply #15 on: March 03, 2014, 08:58:12 PM »
Should be fine unless the bike is very high mileage or was raced where you get a lot of hard accel/decel and clutch kick that stresses the primary.  Dont worry, just worth looking at.
Offline jason405
« Reply #16 on: March 03, 2014, 08:59:30 PM »
Cool. Well I appreciate the head up! I'll definitely give it a look!
Thanks again!
Offline AintNoEasyWay
« Reply #17 on: March 04, 2014, 08:05:31 AM »
Exciting. Gotta hear how all this turns out!
Offline jason405
« Reply #18 on: March 07, 2014, 05:27:15 AM »
Alright. Road block.
So before changing the oil, I went to give the bike the first round of degrease/spray down, so I removed the gauges and wiring harness.  Sprayed it down, then dried it off and removed the exhaust. Then pulled the drain plug, and once that slowed, went to pull the pan.  I'm working my way around the oil pan bolts when I notice one is missing. So I think ok, no big deal, I'll keep going.
So I drop the pan to find the the whole bolt wasn't missing, just half.   Also, there was quite a bit of liquid gasket that had been used AND a homemade paper gasket. Complete with a real estate add and everything! So that has me asking two questions:
1. Why was the liquid gasket and paper gasket used when there is a rubber gasket that makes that seal (which was also in place! And I have a new one.)?
2. How am I going to get that bolt out since it is sheared off flush with the crank case?!
I did some reading on getting the bolt out. What I gathered is avoid the EZ-Out at all cost. Try to drill it out with a left handed drill bit. Any other thoughts here, or suggestions of how to go about it?
Also some little blue silicone type bits in the bottom of the pan. Don't know what that's about but no metal, and the screen is nice and clean.
Offline calj737
  • I refuse...
« Reply #19 on: March 07, 2014, 06:09:26 AM »
A couple of options for removing that bolt: if you have access, weld a little stud to it, then use that to turn the bolt out. Generally speaking, sheared bolts aren't that "stuck" in the block, but some ham-fisted PO over tightened it.
If no welder, then you can apply heat to it (often loosens any corrosion) and attempt to left hand drill it out. If not, I have had success drilling the center of the stud with a quality bit, cutting fluid, and keeping centered on the shaft. This essentially vibrates the bolt loose, and then allows a left hand bit to spin it out quite easily. Or, you can use the hole you drilled, to perhaps get a small needle nosed plier inside and turn out the bolt.
Last resort: EDM at a machine shop.
Blue stuff in oil pan looks like sealant used elsewhere in valve train or inside crank case. A pretty good indication that your PO wasn't very informed not he Do's-Dont's so often found on this Forum by the really experienced builders that keep the rest of us away from mistakes.
Offline jason405
« Reply #20 on: March 07, 2014, 06:19:41 AM »
Thank Calj.
Can I use a torch to heat it since it is right next to the exposed oil cavity in the crank case that has still got oil all over it?
Also I guess I will just have to lay the bike down to be able to drill at it with a reverse bit?
Thanks!
Offline calj737
  • I refuse...
« Reply #21 on: March 07, 2014, 10:52:54 AM »
Use some practical care when heating, and you'll be fine. Yup, lay bike down on its side cover (protection for the bike obviously) and drill carefully. Take your time, use lots of fluid, and be sure you stay centered.
I'd use a bit equal to about 50% of the diameter of the sheared shank.
Offline jason405
« Reply #22 on: March 07, 2014, 10:59:22 AM »
Got it. So I got a bolt extractor set and tap handle. The small size I believe will fit and needs a 7/64 hole.
My plan is to hear from the outside and use a 7/64 left hand bit first to see if that will get it out. If not I'll have my hole ready to try the bolt extractor.
Sound good?
Offline calj737
  • I refuse...
« Reply #23 on: March 07, 2014, 12:19:06 PM »
Sounds like a great plan. You'll be fine- these bolts aren't generally a major problem to get unstuck.
Offline jason405
« Reply #24 on: March 08, 2014, 01:23:34 PM »
SUCCESS!!!!
So we laid the bike over on its side,  and I got a punch on the sheared bolt right in the center.
I decided I would start with the 1/16" in left handed bit to make a pilot hole so the 7/64 bit would have a really positive area to follow.  The saw the bolt move with the first bump of the drill and smiled really big LOL! I guess it wasn't stuck much at all.
Ended up backing right out. That is up there with the best $10 I have ever spent at Harbor Freight haha!
Alright.  Got the gasket surfaces clean and I am going to put the pan back on with just the rubber o ring right? (I have a new one) No liquid or paper gasket needed correct? These bolts had some anti seize on them so should I go ahead and put them back on with some fresh anti seize on them?
Primary chain looked fine to me.
Once I get the pan back on, I am going to try to get as much grime off the motor as I can. Maybe employ the soda blaster for some of that.
I got the POR15 tank sealer in so I will be starting that whole mess soon.  I am going to need a new petcock.  This bike used the 5/8" single fuel line 90 degrees out type petcock.  Anyone know of a solid replacement?
Thanks again for the help getting the bolt out!!!
Jason
