Author Topic: pic needed 78 550 k throttle cable  (Read 410 times)
Offline Bomberman
« on: February 28, 2014, 03:00:53 PM »
trying to find out where the 2 holes are located for throttle cables on pulley on top of carbs, thought there were 2 holes one at each end of pulley
are both holes at same end?
anyone got a close up pic showing where this second cable attaches
if they are at one end and I am not looking hard enough does top cable reach to furthest away hole
hope that makes sense but not easy to explain
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
Re: pic needed 78 550 k throttle cable
« Reply #1 on: February 28, 2014, 08:17:22 PM »
This is a diagram for the type 1 carbs, but I think it should be very similar for your pd style carbs.
Looking closer, I think the cable with the locknut adjustment is the pull cable. I think you have the push cable hooked up to the wrong wheel.
« Last Edit: February 28, 2014, 08:22:01 PM by Frostyboy »
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: March 01, 2014, 03:03:41 AM »
Pull cable will go to the top mount. Make sure the cables are connected properly at the throttle grip. It's not hard to mix those up.
