Author Topic: Ended Up with Two CB750's  (Read 4468 times)
Re: Ended Up with Two CB750's
« Reply #25 on: September 27, 2014, 06:41:43 PM »
What's the issue with the bolts?
Offline DennyK
  • Just kill the one with the sword first. R. Shaftoe
« Reply #26 on: September 28, 2014, 12:53:44 PM »
The bolts are large screw head bolts that require a 6mm Allen wrench. Getting that wrench in a tight spot and applying enough torque was tough. Wish the bolts were a standard 10mm.  Otherwise the parts and advice was great.
« Reply #27 on: September 28, 2014, 02:50:12 PM »
Cant you use a standard hex head 6mm bolt?
Offline DennyK
« Reply #28 on: September 28, 2014, 08:38:12 PM »
Well it is installed now and working.  I have a lot planned for this winter to improve the bike now that it is road worthy.  I will use different bolts when I dive in deeper.  Right now I want to ride the bike and keep checking it out while the weather is still good.
