Author Topic: 1978 CB750K carb changes  (Read 2494 times)
Offline Doggie
  • CB550F, CB650c, CB550k, Cb750K
« on: March 01, 2014, 09:08:37 PM »
I have been reading about carb changes (jets & needle). My 1978 CB750K has a stock air filter but after market 4 into 1 exhaust. Are there any changes to be made?
                                  Thanks, Doug
Offline conwaylale
Re: 1978 CB750K carb changes
« Reply #1 on: March 02, 2014, 08:48:26 AM »
Read through that. It has everything you need to know about carb mods.
http://forums.sohc4.net/index.php?topic=5410.0
« Reply #2 on: March 02, 2014, 08:53:02 AM »
                                  Thanks, Doug
the K8's are lean from the factory.  An aftermarket pipe will typically make you leaner...
Accurate plug chops, starting with new plugs and a WOT chop, will let you know.
Jetting mods in my signature for a pipe slightly more open than stock might help...
Offline AintNoEasyWay
« Reply #3 on: March 02, 2014, 10:19:22 AM »
                                  Thanks, Doug
I've got a CB750 K7 with 4 into 1. I'm looking for an answer on this as well, as I imagine we would need similar jetting. I've just finished rebuilding my carbs with standard specs on everything, but waiting on a couple more parts before I try to start my bike.
Offline Doggie
« Reply #4 on: March 02, 2014, 08:56:37 PM »
I'm rebuilding mine too. (3) times in fact. Mine is hard starting. All jets and passageways are clear, new accelerator pump, new needle and seats, floats set, idle screws set at 1 1/2 turns out, and it still doesn't want to start. Had to crank up the idle to make it start and then slowly drop it down. I'm ready to send it out.
                                Doug
Offline 750K
« Reply #5 on: March 03, 2014, 12:53:24 AM »
                                Doug
Make sure your fast idle cam is set up properly, if its not raising the pistons enough cold starts are really tough. Your manual will tell you how to adjust it properly.
77 Cb750, 78 Kz1000
Offline brewsky
« Reply #6 on: March 03, 2014, 03:28:33 AM »
                                  Thanks, Doug
If you have a stock airbox and filter, and a MAC 4/1 with stock baffle, you may not need any changes, as it is plenty restrictive.
If you open up the airbox, use a K & N, or open up the baffle, have a different brand exhaust etc., you probably will.
Here are my results, yours may vary:
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline Doggie
« Reply #7 on: March 03, 2014, 09:18:28 PM »
Thanks for all the help....Doug
« Reply #8 on: March 04, 2014, 09:07:49 AM »
                                Doug
^^^then your fast idle cam is not working properly.
when you pull your choke knob, the cam, right between #2 & #3 carbs,  will raise the slides slightly, then give her a shot or two of gas with a throttle twist (accel pump shoots gas into the carb throat) and hit the starter or kick it over.  should fire easily.  Fast idle cam (+ the accel pump) properly working is tits!
« Reply #9 on: March 04, 2014, 09:25:37 AM »
Nit pick, perhaps, but I don't believe that true.
They were peak tuned to match the induction and exhaust parameters of production units.  The PD's were considerably less sloppy than earlier carbs which made those earlier carbs "over rich" in nearly every operational range.
Quite true, if you leave the PD's in stock tuning.
If you mess with perfect balance motorcycle tuning, things go awry.
Offline lucky
« Reply #10 on: March 05, 2014, 04:54:07 PM »
If you have the stock airbox and stock air filter all you should need is a slight mixture adjustment -richer.
Offline Doggie
« Reply #11 on: March 05, 2014, 07:23:21 PM »
And you mean richer, as going in on the idle screw. I was 1 1/2 turns out, now 1 1/4 turns?
                                      Doug
Offline 750K
« Reply #12 on: March 05, 2014, 08:39:34 PM »
Air/fuel screw, not idle screw. Pd's have one on each carb body, idle screw doesn't adjust fuel mixture.
77 Cb750, 78 Kz1000
« Reply #13 on: March 06, 2014, 12:17:35 AM »
                                      Doug
The idle screw sets the idle RPM.
The mixture screw (four of them) on the PD carbs adjusts mixture.  Inward leaner, outward richer.
Offline mrbreeze
  • Not your average
« Reply #14 on: March 06, 2014, 01:26:02 AM »
                                Doug
If it a problem with the fast idle adjustment thats one thing but you didn't mention if the carbs have been vac. synched or the state of tune (valves,cam chain,timing,dwell,etc.)You can have the cleanest carbs on the planet but it won't make a sh!t if it isn't tuned & synched.
MEMBER # 257
Black 750K8
« Reply #15 on: March 06, 2014, 04:54:19 AM »
                                  Thanks, Doug
brewsky
 Do you have a pick of just where you placed the four 1" holes in your airbox? Would be a big help.
 Thanks in advance.
Offline brewsky
« Reply #16 on: March 06, 2014, 10:53:13 AM »
                                  Thanks, Doug
brewsky
 Thanks in advance.
See reply #30 in this thread...
http://forums.sohc4.net/index.php?topic=129596.25
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Black 750K8
« Reply #17 on: March 06, 2014, 12:25:53 PM »
                                      Doug
TT:  Very good point a lot of people don't understand that the mixture screws on this (1978 750K) bike works different they are on the other side of the carb. So in or out on the screw is in reverse compared to the non PD carbs.
Black 750K8
« Reply #18 on: March 06, 2014, 12:33:34 PM »
                                Doug
Fly
 I'm in the learning stage on these carbs. I think I remember my uncle (bollingball) talking with you about this fast idle cam. But maybe it was someone else. He is not riding any longer and has a hard time getting out in the shop. But he gave me his bike. :) :)
