Author Topic: 1976 CB550F - making it good, one step at a time  (Read 155943 times)
Offline flatlander
Re: 1976 CB550F - making it good, one step at a time
« Reply #450 on: April 22, 2017, 02:22:24 PM »
yes i'm gonna make them work. sorry but they're not up for grabs any more, i'm gonna stick to them. will have to get them re-coated after all this butchering but what's one more thing at this point....
« Reply #451 on: April 22, 2017, 02:24:09 PM »
No need to apologize, at this point I really want to see them on your bike....
Offline flatlander
« Reply #452 on: April 22, 2017, 02:57:30 PM »
... and you will! just a bit of patience, please.
i was also losing my patience but at this point i'm all zen and just resolved to my fate.
« Reply #453 on: April 22, 2017, 09:58:40 PM »
A more elegant solution (moving the side stand).  Well done!
Offline flatlander
Re: 1976 CB550F - stray air
« Reply #454 on: April 26, 2017, 09:37:43 AM »
finally, the exhaust is on. still some fine-tuning to do, to get everything properly positioned and aligned but the hardest parts are done.
where the mufflers slip over the headers, they're attached with some clamps. enrique's crew cut out some slots so that the clamps could be tightened.
at the top of the slots, there's exhaust gas escaping. any ideas for how to seal this?
« Last Edit: April 26, 2017, 11:08:22 AM by flatlander »
« Reply #455 on: April 26, 2017, 10:53:30 AM »
Fit them, weld them together including the slots for a one piece pipe? Or mark where your clamps sit & weld the rest of the slot closed.
Offline flatlander
« Reply #456 on: April 26, 2017, 11:10:01 AM »
tried to fix the picture. does it work now?
slots don't extend beyond the pipe. there's just a small gap between pipe and muffler that the gas blows through.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #457 on: April 26, 2017, 12:43:05 PM »
What he is saying is that you could weld that bit in the photo that isn't covered by the clamp.
« Reply #458 on: April 26, 2017, 03:24:22 PM »
2 things:
Could be the ceramic just curing somewhat.
That may actually be a drain hole. Check with Enrique. If so, rotate it to the underside.
It's not a drain hole, they cut the slots too long. I was thinking what Brent wrote, weld em. But then you'd have the coating to deal with.
« Reply #459 on: April 26, 2017, 04:18:42 PM »
I might refrain from welding them completely, since this will make it more difficult to remove or replace if you have damage (later).  I would recommend filling the gap with a filler rod weld.  Just my $0.02.
Offline SF
  • I burn gas very well
« Reply #460 on: April 26, 2017, 06:14:33 PM »
Weld em and wrap with a little cloth?
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
« Reply #461 on: April 26, 2017, 10:27:45 PM »
Wrap is for hiding ratty pipes!
Offline flatlander
« Reply #462 on: April 26, 2017, 11:25:08 PM »
it's not a drain hole, and the mufflers can't rotated as they're attached to the frame and to each other.
i might try some exhaust paste first, see if that helps.
don't want to weld just yet, before everything has settled and i'm sure it's all in the right place.
« Reply #463 on: April 27, 2017, 05:36:24 AM »
Are you close to firing it up?
Offline flatlander
« Reply #464 on: April 27, 2017, 06:13:05 AM »
i have fired it up! that's how i know that gas is escaping at the joints.
i am still doing some fine tuning with the bending an positioning, and need to seal those leaks. but getting very close.
Offline flatlander
« Reply #465 on: April 28, 2017, 12:28:59 PM »
right, the damage is done.
had to bend the no.1 header pipe a bit, using a liberal amount of ratchet straps and brute force. but it worked. then i put it all back together using what seemed to me a huge amount of exhaust paste. i also bent the tongues/slots a bit in place to make the gaps even smaller. there are no more gas leaks now.
here's a try at a sound clip, not sure if it will work?
https://drive.google.com/file/d/0B5RVOSoI78N2c2RJSFA1VEtsSVk/view?usp=sharing
and here some crappy garage pictures but you get the idea:
« Reply #466 on: April 28, 2017, 12:40:41 PM »
Sounds friggen great!!!   Refresh my memory - stock motor? Congrats
Offline flatlander
« Reply #467 on: April 28, 2017, 01:04:20 PM »
motor is 59mm wisecos, stage 2.5 mike rieck head with +1mm valves, 126-00 cam.
Offline Scott S
« Reply #468 on: April 28, 2017, 01:18:56 PM »
 Most excellent! I can't WAIT to get mine on! Sounds wonderful. Do you think you'll have to adjust the jetting?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Fezzler
« Reply #469 on: April 28, 2017, 01:40:47 PM »
Those pipes sound awesome.  Deep growl, not just being loud for loud sake.
« Last Edit: April 28, 2017, 01:42:46 PM by Fezzler »
1975 Honda CB550f in parts in progress
1978 Honda CB550 Four K4
1971 Honda CB500 Four K0
2008 105th Anniversary Edition HD Road King
(Sold) 1998 Honda Shadow ACE Deluxe VT750
1973 Schwinn Stingray (Blue Deluxe - RIP Jack and Rose)
« Reply #470 on: April 28, 2017, 02:07:50 PM »
Oh yeah!  The recipe for my future motor build! [for the 550K]  Thanks
Offline flatlander
« Reply #471 on: April 28, 2017, 11:54:41 PM »
thanks guys!
scott i don't know yet... won't get her on the dyno before end of next week and haven't taken her for a ride yet. i expect that stock jetting won't be too far off.
fezz,  yeah i hate loud for loud's  sake. these are by no means quiet and they can't be as the whole point is to have better flow. at least they do it with purpose and style ;)
stev-o, it's a good recipe for a strong yet streetable motor. the full cooking instructions are somewhere further back in this thread.
Offline flatlander
Re: 1976 CB550F - sound check
« Reply #472 on: April 29, 2017, 05:34:33 AM »
went for a shake-down ride today. on my local twisties it pulls vehemently through the whole range up to north of redline. so far so good. did not spend too much time there as there was some popping on decel which may mean it's a bit lean now. but can't be too much the way it was pulling.
as you heard in the clip, the sound is quite tolerable at idle and up to about 3k. when you open it up... there is nothing civil about it. little children will run crying to their mothers. and i am glad i did not pass a church yard because i believe it will make fallen heroes rise from their graves.
when you ride it urges you to crack that throttle open and charge those bends.
there are two spots where the exhaust goop was blown right out of the slots/holes at the joints, need to figure something out for that.
so that's all pretty good so far. still feel like i have an axe to grind with enrique, though. as a matter of principle.
« Last Edit: April 29, 2017, 05:51:46 AM by flatlander »
« Reply #473 on: April 29, 2017, 06:02:45 AM »
Like your description of the loudness levels.  Popping on decel could also be an exhaust leak...
Offline flatlander
« Reply #474 on: April 29, 2017, 07:03:49 AM »
indeed. and i do have some leaks still, where the paste was pushed out. will address that before coming to conclusions because it did not "feel" too lean.
