Author Topic: Parts for a CR750 rear hub  (Read 1350 times)
Offline Jadahonda
« on: March 05, 2014, 07:16:28 AM »
It is probably not easy, but I need a set of brake shoes and the cam-lifters for this hub. Does anyone have these parts for sale, or know if there is some brake shoes who fit?
Thanks, Jan
1958 Honda C70 Dream
1959 Honda C92 Benly
1960 Honda CS92 Ongoing Project
1960 Honda CB92 Benly
1960 Honda CB92 Racer
1961 Honda CB72 Racer
1962 Honda CS92
1963 Honda CB77 Ongoing Project
1967 Honda CB450 Black Bomber
1968 Honda Z50A
1969 Honda CB750 K0
1969 Honda CB750 Sandcast
1969 Honda CR750-Ongoing Project
1970 Honda CB750 Police
1970 Honda CB100
1970 Honda CL100
1970 Honda SL100
1971 Honda CB500
1975 Honda GL1000
1975 Honda CB400F Supersport
1979 Honda CBX 1000, serial number 52
1981 Honda CBX 1000 ProLink
1989 Honda VFR400R (NC30)
  • Moderator
Re: Parts for a CR750 rear hub
« Reply #1 on: March 05, 2014, 05:32:31 PM »
Have you tried the front shoes from the CB72/77 Jan ?
Sam. :)
Offline Jadahonda
« Reply #2 on: March 06, 2014, 05:03:11 AM »
I will try. Maybee the diameter fits, but I guess they are smaller (width) than CR750 shoes? Maybee someone can tell me the width on them?
Jan
1962 Honda CS92
1968 Honda Z50A
1969 Honda CB750 K0
1970 Honda CB100
1970 Honda CL100
1970 Honda SL100
1971 Honda CB500
1975 Honda GL1000
Offline Tintop
« Reply #3 on: March 06, 2014, 08:53:58 AM »
Do you have the original shoes?  A lot of guys over here just have new lining material applied to worn out shoes, and the surface re-arked to fit the drum.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
  • Moderator
« Reply #4 on: March 06, 2014, 03:26:53 PM »
8" TLS Brian.
Sam. ;)
Offline Tintop
« Reply #5 on: March 06, 2014, 03:50:13 PM »
8" TLS Brian.
Sam. ;)
front GT 750, Yamaha TZ....if he's got the shoes they can be relined Sam.  That said if they're magnesium, they may be too brittle by now, and should be crack tested.  This is the one most use / recommend over here - http://www.phoenixfriction.ca/  The other is Vintage Brakes.
77 CB550 Cafe build
  • Moderator
« Reply #6 on: March 07, 2014, 01:31:04 AM »
Jan, If this helps, I've just measured a CB92 front set up which I think is the same as the CB72/77 set.
Lining width is 30mm, shoe width at the pivot location is 20mm, distance between pivot centers is 165mm.
Overall diameter of shoes in closed position is 200mm at a guess allowing for mine having wear.
Sam. ;)
Offline Jadahonda
« Reply #7 on: March 11, 2014, 09:26:34 AM »
Many thanks!
I will try a set of CB92 front /CB72 brake shoes. i know they are the same. I will come back when I have tried them.
Jan
1962 Honda CS92
1968 Honda Z50A
1969 Honda CB750 K0
1970 Honda CB100
1970 Honda CL100
1970 Honda SL100
1971 Honda CB500
1975 Honda GL1000
