Author Topic: 1975 CB550K1 - Stock-ish Restomod - More Mods  (Read 154243 times)
Re: 1975 CB550K1 - Stock-ish Restomod - More Mods
« Reply #275 on: April 30, 2015, 04:50:56 PM »
It made a significant improvement in handling -- along with a front fork brace.
Offline riverfever
« Reply #276 on: April 30, 2015, 07:23:20 PM »
Ummmm...really? I'm over here slaving away with blisters on my fingers and you post up this hotness? Damn those look nice. Someone polished those out for you?
« Reply #277 on: April 30, 2015, 07:27:41 PM »
So, both my vintage AP calipers
and my new AP Racing (twin 41.3 mm pistons) would not clear the Lesters:
imagejpg1_zpsde39ea01 by Donald Leonhardt, on Flickr
So here are some of the candidates to replace my stock dual calipers:
Brembo F05 calipers (single 32 mm pistons) -- harder to find, but compatible with thinned stock rotors and AHRMA approved
brembo f05_zpsplv62y6s by Donald Leonhardt, on Flickr
Brembo (two 30 and 32 mm diameter pistons which are thermally insulated ) OEM for Ducati Sport Classic:
1_zpsp78bfn4i by Donald Leonhardt, on Flickr
5_zpsabazepkl by Donald Leonhardt, on Flickr
« Last Edit: July 05, 2017, 11:03:32 AM by SOHC4 Cafe Racer Fan »
« Reply #278 on: April 30, 2015, 07:29:31 PM »
Shamefully, YES.  $30 to polish the pair to a mirror finish and I got them back within a week.
« Reply #279 on: April 30, 2015, 07:34:27 PM »
Oh, and I replaced my Emgo blinkers/indicators:
With these from K&S Technologies (http://www.kandstech.com/)
Offline Restoration Fan
  • My wife will never call me
« Reply #280 on: May 01, 2015, 05:32:01 AM »
NOTHING to be ashamed about there.  If I had someone who could have polished ours for $30, I would have had them in his hands before the "s" sound was finished in the word "dollars".  We spent several hours on our fork lowers to get them back to presentable stage.
In our case, I'm glad we did it so that Logan could get the experience but that's a job that I would gladly hire out for that low of a cost.
« Reply #281 on: May 01, 2015, 05:33:38 AM »
since those APs won't fit your bike, better send them to me... Do the new indicators use LED bulbs? If not... www.superbrightleds.com
Cal, if I wanted to put one of those kits on my 750, where do you guys get the reflectors to take the place of the sealed beam bulb look?
« Reply #282 on: May 01, 2015, 06:31:42 AM »
If the LED bulbs are like the ones on my headlight, there are LED diodes in multiple directions.
« Last Edit: May 01, 2015, 09:20:51 AM by CB750 Cafe Racer Fan »
« Reply #283 on: May 01, 2015, 06:34:50 AM »
Don,
I get that but my bulb is a sealed beam system.  So to put LED's in, I'm going to have to replace that lens and reflector with one that accepts the LED's.  I'm just wondering where you guys get such a lens/reflector kit from?
Offline Davez134
« Reply #284 on: May 01, 2015, 07:21:24 AM »
I'm glad it was easy for you with no diodes. I tried that on both my bikes with no luck, ended up having to make a small 3 wire in-line harness. Bike looks great!!
« Reply #285 on: May 01, 2015, 08:03:02 AM »
Don,
Ahh. I purchased that lens years ago. I think I bought it from Carpy. One of his tri-bar lenses. The reflector was built in. I, too, got confused since my mind was on the blinker change.
NOTE: if you google tri-bar 7" headlight, you will find vendors selling the housing with the reflector for less than 1/2 of what Carpy prices his at or DCC.
« Last Edit: May 01, 2015, 09:48:11 AM by CB750 Cafe Racer Fan »
« Reply #286 on: May 01, 2015, 09:24:34 AM »
Cal,
Are you referring to a flash relay?  By diodes, I was referring to Light Emitting Diode -- the actual light producing part of the LED bulb.
The turn signals I just installed have regular bulbs.  If I swap them out for LEDs (like my headlight), I probably will need a digital flash relay, since this bike has Older School wiring.
« Reply #287 on: May 01, 2015, 09:49:30 AM »
Yep!!
Offline Davez134
« Reply #288 on: May 01, 2015, 09:52:31 AM »
I was referring to diodes. These are not necessary when the turn signal bulb is an LED. But, the flasher relay is also integrated with the m-unit. Old school wiring  :o
The diodes should only be necessary to isolate the idiot light when the is a single light for turn signal ON but there are 2 channels supplying that signal (L or R). The diode prevents the L side from blinking, the idiot light from illuminating, then back feeding into turning the R side on also. Make sense?
Yep, that's exactly what I was fighting with! <--- An idiot needs his idiot lights ;D
Offline onetruepunk87
« Reply #289 on: May 01, 2015, 10:27:43 AM »
I had to deal with putting diodes in when I installed my mini gauges with the idiot light built in on my 750. Not too much of a hassle but I had a wiring cheat sheet someone else had previously posted.
« Reply #290 on: May 01, 2015, 10:30:40 AM »
I think that Brent (bwaller) uses Brembo F05s on his 550 race bike with thinned rotors.  I was concerned that the smaller single pistons might not offer as much stopping power as the other calipers, but if they work for Brent under race abuse, they should be fine.
For now, I will probably just run the bike with the stock, squeaky dual calipers.  This bike has been off the road too long, and I want to enjoy the new paint!
« Reply #291 on: May 01, 2015, 06:18:48 PM »
Weekends were made for riding!  Still need a new mirror though!
New signals, master cylinder, newly rebuild forks and fork brace:
Pro-Taper clutch lever (much easier pull) and milled switchblock:
image_zps1bcwswoz by Donald Leonhardt, on Flickr
NOS Lesters, new BT45s, new brake stabilizer:
Love the new bodywork painted Planet Blue Metallic
« Last Edit: July 05, 2017, 11:05:53 AM by SOHC4 Cafe Racer Fan »
Offline Bigsam302
    • 1976 CB750F (915cc) Super Sport
« Reply #292 on: May 01, 2015, 06:36:02 PM »
That looks amazing!
1976 CB750F (915cc) Super Sport: http://forums.sohc4.net/index.php?topic=142578.0
Offline riverfever
« Reply #293 on: May 01, 2015, 06:46:26 PM »
Don that bike looks wonderful! Love it.
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #294 on: May 01, 2015, 06:48:59 PM »
Don... A black Lucas style taillight would look pretty sweet with those new black indicators. Love the new touches! Looks like a completely different scooter.  - Kyle
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
« Reply #295 on: May 01, 2015, 11:32:39 PM »
#$%*ing killer 550
« Reply #296 on: May 02, 2015, 12:15:58 AM »
Thanks, guys. I'm really happy with it!
Offline rtbmrgl
  • Got Points! Roseville, Ca
« Reply #297 on: May 02, 2015, 07:41:29 AM »
$30 really, what a bargain, where is this place. Also i didnt realize you could do clear powder coating. What did pay for powdercoat, its expensive up here in, place by me wanted $5-600 for a frame and pieces
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
« Reply #298 on: May 02, 2015, 10:14:15 AM »
Hi Mark,
I gave them to my painter Bondo and he has a guy who picks up and drops off polishing. I just gave him my crusty forks assembled and he gave them back shiny with my spare parts. Cannot argue with that for $30!
My buddy Jay sent the forks out for clear powdercoating with other parts from his shop. We did a trade for some spare parts I bought from KrautKoffin so it was a wash.  ;D
« Reply #299 on: May 02, 2015, 10:39:17 AM »
Did you drag your butt over to the Nomination thread and accept yet?
?! Holy smokes. Didn't see it until now. Thanks!!
