Author Topic: 1975 CB550K1 - Stock-ish Restomod - More Mods  (Read 154224 times)
Offline onetruepunk87
Re: 1975 CB550K1 - Stock-ish Restomod - More Mods
« Reply #300 on: May 02, 2015, 10:44:17 AM »
Bike looks great! I need to get off my computer and back into the garage.
« Reply #301 on: May 08, 2015, 06:38:44 AM »
Lost cylinders 2 and 3 during my last ride. Checked but could not find a loose wire to the coils. Need to check the coil.
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #302 on: May 08, 2015, 06:41:56 AM »
Bummer, Don. Without looking back, what are you running for your complete ignition?
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
« Reply #303 on: May 08, 2015, 06:55:11 AM »
Dyna 2000 and green coils.
Offline Scott S
« Reply #304 on: May 09, 2015, 09:45:11 AM »
 The green paint set from VMR, is that Candy Jade Green? It seems darker than most Candy Jade pics I've seen.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #305 on: May 09, 2015, 11:04:52 AM »
I agree Scott.  I think that may be a product of my painter laying on the candy heavier, but I like it.  Achieving a perfect stock look was not my goal, but staying closer to it than a full custom.
« Reply #306 on: May 16, 2015, 06:07:55 PM »
Electrical gremlin resolved!  Of course, when I started the bike again, cylinders 2 and 3 fired with no problem.  I took it over to my buddy Jay.  All of the connections were good.  We found out that the wire to the coils had an internal break -- just enough so that the wire would/would not make a connection if bent enough.  Wire replaced.  Problem solved!!
After a new clutch and springs and a oil change, the bike is running like a champ!!
« Reply #307 on: May 22, 2015, 11:41:55 AM »
A couple of people asked about the paint.  It is Honda Planet Blue Metallic from RS Paint in the UK http://www.rsbikepaint.com/en-us/shop-paints.php?colourscheme=3963&6847=on
Their paints are water-based and much less expensive than VMR.  VMR also has a great looking Planet Blue Metallic.
Offline rtbmrgl
  • Got Points! Roseville, Ca
« Reply #308 on: May 27, 2015, 11:13:43 AM »
paint looks good, paint cheaper, but they get $110 for shipping to the states.
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
« Reply #309 on: May 27, 2015, 11:30:46 AM »
Mark,
Check again.  I paid $38 for shipping.  I paid less than $90 for the metallic paint AND shipping.  Much cheaper than VMR.
Offline 2strokeTrush
  • Can you get that back together sonny?
« Reply #310 on: May 28, 2015, 07:37:39 AM »
How long did it take to get your paint delivered?  I just ordered some from the same site, thanks for the heads up! I was dreading paying the VMR price  :o
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
« Reply #311 on: May 28, 2015, 07:50:13 AM »
It was about 2-2.5 weeks from the order date. VMR took a month.
« Reply #312 on: June 01, 2015, 12:17:37 PM »
I gave the 550 a solid ride this weekend.  Something I noticed: on deceleration without braking between 49-45, I get some head shake/bar shimmy if I don't have a solid grip on the bars.  The wheels are balance, no crash damage to the frame, newly rebuilt forks and new wheel and newer steering head bearings (1 year old).  Nothing violent or dangerous, but a little odd.  I don't think the Tarozzi fork brace is causing it.  I was thinking of installing a steering damper just in case.
Opinions??
Offline Tews19
  • I am no
« Reply #313 on: June 01, 2015, 12:30:43 PM »
A glorious attribute the 550s all have had that I've owned is the ability to let the handle bars go while riding. I've never had the mods that you have done but I never needed to for the riding I do..... Alright truth be told the funds don't allow me too! Have you rechecked the tightness of the triple tree? Could possibly be poor tapered bearings? HondaMan made a post on how sometimes a batch or two tapered bearings just do not hold up. Something possible let to check?
1970 Honda CB750 survivor.
« Reply #314 on: June 01, 2015, 12:41:31 PM »
I don't think it's the bearings since I had them with the same trees for the last year.  I may have to adjust the steering stem bolt.
« Reply #315 on: June 01, 2015, 02:01:34 PM »
I have found that tapered steering bearings will need to be re-adjusted sometimes a couple times in the first 5000 miles
« Reply #316 on: June 01, 2015, 02:08:57 PM »
what rubber you running on that bike CRF? And tire pressure is...?
Brand new BT45s front and rear inflated to spec.
Offline Tews19
  • I am no
« Reply #317 on: June 01, 2015, 02:31:30 PM »
That's what I meant. Also how sometimes once torqued they can become "flat", not as smooth. But that's rare according to HondaMan. I had one set go bad in less than 6 months. Contacted All balls and they sent me new ones.
« Reply #318 on: June 01, 2015, 02:37:57 PM »
Thanks, guys.  I will look at it more tonight.
Offline joeyvans
  • Definitely not a
« Reply #319 on: June 01, 2015, 02:56:41 PM »
Don - Congrats on the BOTM win! Well deserved!
1976 CB550 K2
« Reply #320 on: June 01, 2015, 03:06:50 PM »
Thanks.  Like I said in the vote thread, I'm glad it was so well received by our crowd. I rode it to a Downtown Huntington Beach bike spot yesterday and nobody gave it a second look.
Offline riverfever
« Reply #321 on: June 04, 2015, 08:32:48 PM »
Congratulations Don.
« Reply #322 on: June 04, 2015, 11:45:52 PM »
Thanks, Chris.  This bike made me a big fan of 550s.
Offline straat-toe
  • Everybody knows about the bird.
« Reply #323 on: June 05, 2015, 01:42:32 AM »
Good job with the win! A very cool 550. It's all in the detail.
No School, No Job, No Worries.
« Reply #324 on: June 05, 2015, 06:48:02 AM »
Thanks. On this bike, I was trying to exercise some restraint on the modern mods.
