Author Topic: 1975 CB550K1 - Stock-ish Restomod - More Mods  (Read 154114 times)
Re: 1975 CB550K1 - Stock-ish Restomod - More Mods
« Reply #450 on: December 08, 2016, 07:49:16 PM »
So, no high compression 592 dynoman piston kit with a MRiech ?spelling, sorrk Mike I can't keep it straight?  Stage 2 or 3 head porting work and good streetable cam yet?
I guess the dual discs will lessen any twisting forces caused by a single disc.  The stock font end flex quite a bit compared to modern setups, but you tranfer the stiffness of a stronger front end you just move the force into the frame.  You reach a point you can't improve it.  Most never or rarely push the bike to detect it or appreciate understand how much it impacts the cornering and handling.  You have a good fork brace that lessens the twisting greatly.
You may want to play a bit with the viscosity of the fluid given your new brakes will  change the rate of dive if you aren't carefull even with the gold emulators.
Nothing wrong with blending fork oils if they are the same material/oil. So, a 10% 20W with 90% 10W puts you into a blend not easily available in std selections without moving to a silicone-based fluid unless the dirt bike riders have it and I am unaware of it.  Just speculation on my part.  I may be totally off base.
David
« Reply #451 on: December 08, 2016, 07:56:48 PM »
David
David,
This bike is a struggle to leave it alone.  I wanted to keep it closer to stock.  Since the motor was in such good shape, I did not rebuild, but only refreshed the top end.
The stock exhaust was rusted through, otherwise I would have kept it.  The replacement was fine, but I wanted to try a different pipe.
I kept the brakes semi-period correct up to now, but they are somewhat subtle since I went with black.
I am not going to do any more serious mods.  If the engine ends up needed a rebuild down the road, I might just do a +1 over.
This bike runs like a sewing machine.  It's a great little fun bike.
« Reply #452 on: December 08, 2016, 08:49:18 PM »
Yes, the 550 is my favorite...guess you just need another to scratch an itch or play with if funds aren't a huge issue as going through it again can't impact your rainy day fund or kids college or retirement if you are smart.
 ( my opinion)
Odds are it won't measure up to the 650 experiment "Hot Mess" bike, so maybe there isn't an itch to scratch.  Keeping the bike a mild resto mod is appropriate in this case.
Hope you are enjoying it.  If you decide to experiment with fluids, maybe a friend with a truck and supplies and you could do it in the field with supplies and cleaning  materials as well as protection against spills. That way you run tests close to the same conditions and less has to be relied on for memory.  Splitting the difference between a heavy mix of maybe 30% 20W at first, presuming you are running a 10W now. The spitting the difference on amount of heavier oil mix % will allow you to quickly zero in on the mix that helps, if it helps. The split allows you to quickly find the solution if one exists.  ;D
Only downside is less excuses to need to go ride the canyons on repeated days if that kind of excuse is needed...
Offline flatlander
« Reply #453 on: December 08, 2016, 11:08:02 PM »
don, does it "need" the dual discs with that brake? would one not be strong enough and save weight?
Does it "need" them? No. Beringer wanted to prototype the brackets for a dual rotor set-up so who was I to argue?
of course! i was only wondering... coz it looks an excellent upgrade but sounds like two might be overkill for someone who's not a guinea pig  ;)
« Reply #454 on: December 09, 2016, 08:48:14 AM »
 ( my opinion)
You just hit the nail on the head there.  I have the 650 Hot Mess to up the performance quotient.  This one I am trying to keep more original.
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #455 on: December 15, 2016, 09:39:08 PM »
Beautiful bike man!
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
« Reply #456 on: December 15, 2016, 10:14:25 PM »
Offline SF
  • I burn gas very well
« Reply #457 on: December 17, 2016, 07:10:43 AM »
This is a classy build+
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
« Reply #458 on: December 17, 2016, 08:06:17 AM »
Thanks!
« Reply #459 on: December 27, 2016, 08:14:15 PM »
Been hiking in Joshua Tree for the last two days.
IMG_0688_zpsqjruglm0 by Donald Leonhardt, on Flickr
IMG_0690_zps9dvad8he by Donald Leonhardt, on Flickr
My buddy's at Beringer are waiting for the revised prototype caliper mount, so they took liberties in installing my new Hindle 4-2-1 exhaust system.
IMG_0708_zpspej2izul by Donald Leonhardt, on Flickr
IMG_0709_zpsmqgmmqbx by Donald Leonhardt, on Flickr
IMG_0710_zpsmgqkjvrc by Donald Leonhardt, on Flickr
IMG_0711_zpsnbersxoi by Donald Leonhardt, on Flickr
IMG_0712_zps9kfps4bv by Donald Leonhardt, on Flickr
« Last Edit: July 05, 2017, 05:28:17 PM by SOHC4 Cafe Racer Fan »
« Reply #460 on: December 27, 2016, 10:10:10 PM »
Have you visited that park called Devil's something that an episode of the original Star Trek was filmed in.  It is an interesting place to spend a few hours.  Going to go up to Edwards and take a tour?  They have some really cool stuff.
David
« Reply #461 on: December 27, 2016, 10:33:05 PM »
David
Vasquez Rocks.  Also in the high desert but different area.
https://en.m.wikipedia.org/wiki/Vasquez_Rocks
« Reply #462 on: December 28, 2016, 08:44:32 AM »
Nice park Don, are you listening to U2 too?!
What are you doing with the old exhaust?
Give us a write up on the Hindle once you get a chance to do a road test.
« Reply #463 on: December 28, 2016, 09:04:02 AM »
As a matter of fact, yes we did. It seemed. Like fitting soundscape.
I'm not sure what I'll do with the old pipe. Might pass it along to a buddy for his project.
Offline Pan1cReaper
« Reply #464 on: December 28, 2016, 09:48:07 AM »
Looks good with that exhaust. I like the mags and the slimmed down rear lights, while keeping it OEMish. I sometimes wish I had kept the stock seat and slimmed it down some, but got caught in the craze.
Offline riverfever
« Reply #465 on: December 28, 2016, 11:43:11 AM »
The Hindle looks pretty snazzy there Don.
Offline Restoration Fan
  • My wife will never call me
« Reply #466 on: December 28, 2016, 12:21:05 PM »
Thank you.  I accept!  :D
« Reply #467 on: December 28, 2016, 01:39:23 PM »
Wait a min, Ron. I asked first!
« Reply #468 on: December 28, 2016, 02:19:34 PM »
You asked what he was doing with it.  He said he was potentially offering it up to a buddy and I figured that was obviously me.  Hence, I accepted Don's gracious offer.  Now, Don and I might be willing to make you a great deal on it though.
(Psst...Don, do I get a commission if we sell this thing to Stev-o?)
Offline riverfever
« Reply #469 on: December 28, 2016, 02:41:20 PM »
Don can't talk right now. He's too busy looking for streets that have no name.
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #470 on: December 28, 2016, 02:47:56 PM »
Yuck.... I hate U2. Yes, they do good things... just can't stand Bono. Piss poor reason, I know. Gained respect for Edge after I watched "It Might Get Loud" for the first time. But I digress.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline riverfever
« Reply #471 on: December 28, 2016, 02:51:58 PM »
Last night Don said he wanted to feel the sunlight on his face. But he also said it was only 36 degrees and that's not balmy enough for sunlight on his face. He actually sounded a little bitter about it. Kinda like Joeyvans towards Bono kinda bitter.
Offline joeyvans
  • Definitely not a
« Reply #472 on: December 28, 2016, 02:55:47 PM »
Bono is in the same category as Chad Kroeger.... IMHO.  It's 29* with sunshine on my face right now. Feels like Tshirt weather.... and I'm not kidding.
1976 CB550 K2
Offline joeyvans
  • Definitely not a
« Reply #473 on: December 28, 2016, 03:11:14 PM »
All I know is that's we're lucky JW has left the building. Im sure he and Bono are mates and he'd be pissed with Joey for dumping him in the bin. Phew! Crisis averted  ::) :P
+1   I wouldn't be able to go blow for blow with that clown without losing my sh%t and getting booted from the forum. But I think we can all secretly agree that we miss some of the back and forth????? Comedic relief????? No?
1976 CB550 K2
Offline riverfever
« Reply #474 on: December 28, 2016, 03:18:15 PM »
Bono probably digs fur coats.
And I do not miss the back and forth or the drama that always happened when the Wild was popping off. I enjoy this place and what I saw every time he appeared was sad and pathetic.
