SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
large oil filter housing
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: large oil filter housing (Read 848 times)
monkeyrocco
Full Member
on:
March 08, 2014, 11:57:18 pm »
hi all, i came across a oil filter housing it is the same diameter as a standard one but a inch longer any ideas what its off ?
cheers rocco
Logged
have fun ride safe
City Boy
Hot Shot
Re: large oil filter housing
Reply #1 on:
March 09, 2014, 05:51:30 am »
Hi Rocco.The part you mention is I believe the filter housing for CB350 four and CB400F..This housing holds 6 more oz. of oil than the 750 /550 housings. I have these fitted to both my 750 and 1100F.It also uses the standard 750 filter but has an aluminum spacer and a longer filter bolt than 750.You will find visual of what I describe on a 350/400F parts diagram.
Logged
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
onepieceatatime
Hot Shot
Reply #2 on:
March 09, 2014, 06:04:05 am »
The SOHC CB650 also had a longer oil filter housing.
Logged
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
City Boy
Hot Shot
Reply #3 on:
March 09, 2014, 06:30:13 am »
Yes that is correct.CB 650 would be same parts as I described.Looking at parts diagram I see that 650 also used 350F (333) centre number for bolt and spacer/collar.
Logged
'83 1100F
monkeyrocco
Full Member
Reply #4 on:
March 09, 2014, 03:38:55 pm »
thats great thanks for that, just wondered what it was
Logged
have fun ride safe
Doggie
Hot Shot
CB550F, CB650c, CB550k, Cb750K
Reply #5 on:
March 09, 2014, 08:33:42 pm »
When I took off my oil filter housing on my '76 CB550F, I found an aluminum spacer under it. Turned out to be a spacer so that you can add an oil cooler to the oil filter. Had (2) fitting holes in it that were plugged.
Doug
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
