Author Topic: Over the winter…spokes...  (Read 6243 times)
Offline Roach Carver
Re: Over the winter…spokes...
« Reply #25 on: September 11, 2006, 04:06:25 PM »
sparty, heres what I got. "Assuming the rims are in decent shape, that wouldn't be a problem.  It's $79 a wheel to build.  Spokes are between $70 (chrome) to $130 (stainless) per wheel plus shipping of $25 per wheel.  thanks,". I requested some good contact info to post here. As soon as I get it thats what I'll do.
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #26 on: September 11, 2006, 04:10:24 PM »
71,
Thanks for the info.  It looks like his prices are real close to Buchanan's.
Sparty
1972 CB750 K2 Cafe' Style
Offline gtyler5
« Reply #27 on: September 11, 2006, 04:33:57 PM »
partsnmore.com has standard spoke sets for $30.00... stainless would be nice though.
1976 CB750F cafe
1978 CB750F (in progress)
1993 CB750 Nighthawk
Offline jevfro
  • 1975 CB750 K5
« Reply #28 on: September 11, 2006, 07:30:53 PM »
I got the partsnmore $30 spokes and am very happy.  I might be doing it again sooner than if I used ss but the originals lasted 30 years and I believe they're lighter than the ss too.  As for the DIY recommendations I totally agree... You might want to polish your hubs up or at least clean the works up real good while it's all torn apart. I just relaced and got them close to true.  the local Honda shop had a good mechanic there who trued them and mounted new tire/tube for $60.  here's the thread on my wheel rebuild
http://www.sohc4.us/forums/index.php?topic=11993.0
« Last Edit: September 12, 2006, 03:33:14 PM by jevfro »
Offline cbjunkie
  • ...know what i'm sayin'?
« Reply #29 on: September 11, 2006, 11:21:58 PM »
VIQ
very important question...
for all you guys that have done your own spokes please please please tell us about the nipple wrench that you chose to use...
i am on my 5th time through trying to get these right and i'd say about half of them are breaking down, losing shape, rounding off and at the worst, god rest my soul, breaking up into fragments.
i am wholly discouraged right now and need some solid advice.
i haven't been able to ride for three weeks and am at the end of my rope...
junk out...
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
Offline oldbiker
  • I HATE RAIN
« Reply #30 on: September 12, 2006, 12:15:55 AM »
The HOP in the rim at 1mm is acceptable.  Remember though that when manufactured the rim is rolled and welded, and where the weld is there is always a very slight flattening. Is this what you have noticed as a hop?
Offline cbjunkie
« Reply #31 on: September 12, 2006, 08:48:45 AM »
i believe that is it - there does seem to be a weld there - although well polished it is slightly noticeable on the inside of the rim - i hadn't realized that's what it was - thanks.
1971 750K1
the free men.
« Reply #32 on: September 12, 2006, 04:12:39 PM »
heres the info for the guy on ebay taht will lace and true your wheels, but as sparty pointed out he is comparable to buchanons prices.
 970-310-5344 and I live in Fort Collins, CO.  The best email address for me is lessarde@ayresassociates.com.  thanks,
animal
« Reply #33 on: September 19, 2006, 03:36:46 PM »
Everyone who rides and wrenches needs to know how to lace a rim. I'm here trying to find sohc spokes for a harley 16" rim on the back of a old cb750F. Here's how you do it, works on harleys should work on hondas, wheels is wheels. Make a trueing stand out of wood if you do not have a high $ cast iron one. Just two uprighta that support the axle and allow the hub to spin freely without moving back and forth. A v cut into the top supports works fine. Be sure the axle is level. Mount old wheel in stand and slide 2 - 2x4s up tp the edge of the rim so as it litely touches the rim across both edges one 2x4 across both beads front one 2x4 across both beads back. Now the rim should be able to set there solid even it there were no spokesand remain centered on the axle. I see a problem with my discription the 2x4s go front and back of the rim in the manor of that if the rim was on the bike one would keep the bike from rolling forward and one would keep it from rolling back like chocks. Now mark the edge of the rim where it rests on the 2x4s this will give you the position to put the rim when you relace it, be sure the hub can not move back and forth. Loosen all the spokes. remember where each one goes, take pictures. draw drawings whatever. Take off the nipples one at a time if possible and replace them with he fancy new ones, leave them very loose untill they are all replaced with the nipples all loosely attached. Now buy a case of beer, open one take a sip repeat as necessary. slowly one spoke at a time turn the nipple one turn go clockwise to the next spoke turn it one turn etc etc till they get sorta tight being sure the rim is still between the marks on the 2x4s.Now the rim shoul be fairly stable remove the 2x4s and fix something next to the edge of the rim that cant be easily moved. spinn the rim and check for a wobble.  or out of roundness tighten the spokes necessary to make it round. If you run out of beer stop!!!!! Start again 24 hrs later this time sober. Slowly adjust the spokes till the wheel spins with no wobble or out of roundness, take your time. The first time takes a while, sometimes a long while. Never tighten a spoke to tight a torque wrench helps but wou can click the spokes with a wrench and hear the tone they make they should all clink at the same pitch. Now spin the wheel, it should spinn smoothly and not wobble. Now go have some beer. Steve
