Author Topic: Fusebox replacement on CB400F  (Read 3855 times)
Offline Prof_LaGuerre
« on: March 11, 2014, 10:36:48 PM »
Hi all, been having issues with main fuse getting super hot to the point it melted my box enough to be concerning. I read to clean the clips, but at the state that it is in, I'd rather replace the whole thing.
Now the question is, I have found fuse boxes for 550s and 750s more readily available and usually cheaper than for the 400, would these fit correctly without any significant modifications? Any advice or thoughts on the matter would be greatly appreciated.
Thanks in advance!
Offline becken
Re: Fusebox replacement on CB400F
« Reply #1 on: March 12, 2014, 06:03:41 AM »
1976 CB550F bought new
1981 CM400A wife bought new
2004 GL1800
Offline thirsty 1
« Reply #2 on: March 12, 2014, 02:43:00 PM »
Mine came from a 360t off of eBay. I think they're all the same.
Offline FuZZie
« Reply #3 on: March 12, 2014, 02:47:18 PM »
Check with Hondaman
http://sohc4shop.com/catalog/product_info.php?cPath=23&products_id=48
+1
I have Hondamans fuse box on my 400f, lots have looked right at it and no one even notices that it's been upgraded to blade fuses! ;)
Offline becken
« Reply #4 on: March 13, 2014, 04:46:51 AM »
Hondaman builds them himself for the bike it's going on.
2004 GL1800
« Reply #5 on: March 13, 2014, 12:24:38 PM »
It is used on all these bikes
CB400F A MOTORCYCLE, JPN, VIN# CB400F-1000006 TO CB400F-1038492
CB400F A (76) MOTORCYCLE, JPN, VIN# CB400F-2000001 TO CB400F-2008280
CB400F A (77) MOTORCYCLE, JPN, VIN# CB400F-2100001 TO CB400F-2104166
CB500T A MOTORCYCLE, JPN, VIN# CB500T-1000001
CB500T A (76) MOTORCYCLE, JPN, VIN# CB500T-2000001
CB550F A MOTORCYCLE, JPN, VIN# CB550F-1109886
CB550F A (76) MOTORCYCLE, JPN, VIN# CB550F-2000003 TO CB550F-2010866
CB550F A (77) MOTORCYCLE, JPN, VIN# CB550F-2100001 TO CB550F-2114871
CB550K A (77) MOTORCYCLE, JPN, VIN# CB550K-2000007 TO CB550K-2015308
CB550K A (78) MOTORCYCLE, JPN, VIN# CB550K-2100001 TO CB550K-2122082
CB750A A (76) MOTORCYCLE, JPN, VIN# CB750A-7000001 TO CB750A-7007331
CB750F A MOTORCYCLE, JPN, VIN# CB750F-1000002 TO CB750F-1015054
CB750F A (76) MOTORCYCLE, JPN, VIN# CB750F-2000003 TO CB750F-2022317
Here's one if you want stock style
http://www.partsnmore.com/parts/honda/cb550/?filters%5Bcategory%5D=electrical&filters%5Bmodel%5D=cb550f&filters%5Bfitting%5D=custom
http://www.vintagecb750.com/products/5/45/64/wire-terminals-couplers-fuse-boxes-fuses
David Silver Spares restores 400F and has MANY new and reproduction parts for your bike just not the fuse holder.
Offline MoMo
  • Ride like you're invisible
« Reply #6 on: March 13, 2014, 01:10:00 PM »
While you're replacing the box go through the entire system cleaning all terminals and grounds, especially the connector from the rectifier...Larry
Offline Ericcb750
« Reply #7 on: March 13, 2014, 01:16:36 PM »
I just ordered one from Hondaman for my 750 and it bolts right into where the stock fuse box went. It's upgraded to the blade style fuses. I found it such a pain in the arse to get the glass fuses in the correct size (length). His also stores spare 3 fuses as well. Haven't gotten it yet but i've seen pictures and it looks really nice.
1978 CB750K
1978 CB750F super sport
2005 Sportster 1208
Offline grcamna2
« Reply #8 on: March 13, 2014, 01:32:28 PM »
+1 on cleaning ALL the many ground connections to frame.  8)
« Reply #9 on: March 13, 2014, 02:52:42 PM »
Thanks everyone! Absolutely going to check Hondaman, and good info on all the cross fitting units. Also just replaced my rec and cleaned the contacts through a good deal of the electrical system while troubleshooting.
